Rough In Electrical Inspection For Kitchen Remodel - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2013, 07:00 PM   #1
Rough in electrical inspection for kitchen remodel
We pulled home owner's permit for our kitchen remodel, and I started to get very worried about the upcoming electrical inspection. I took some pictures of the outlets and hopefully someone can let me know whether they'll pass the inspection.
This is the wire for the DW
outlet for fridge . We'll just keep it as is.
This is one countertop outlet, GFCI
This is the only dedicated line in the kitchen, also a countertop outlet
I hope the pictures loaded ok. Thanks!
cinderellaii is offline   Reply With Quote
Old 05-29-2013, 07:03 PM   #2
Rewards Points: 13,300
Got me scared with that first picture.
Where's the outlet?
All outlets over the countertop need to be GFI and no more then 4' apart.
Is this all 12-2 wiring?
Do you have two circuts for the kitchen?
Old 05-29-2013, 07:04 PM   #3
By the way, I am in East Brunswick, NJ.
Old 05-29-2013, 07:11 PM   #4
Should I use a grounding type attachment plug for it?
Old 05-29-2013, 07:20 PM   #5
Where's the outlet?
I have three circuits coming into the kitchen, but two of them are more or less shared. Yes the outlets over the countertop are GFI and no more than 4' apart. The new wires are 12-2. I am not sure about the old wires.
These are my outlets over the countertop.
Old 05-29-2013, 07:56 PM   #6
deverson's Avatar
Rewards Points: 77
Not sure why you used 20 amp GFCI's as you could have used 15's. the BX laying on the window sill probably won't pass inspection. Just my opinion though!
deverson is offline   Reply With Quote
Old 05-29-2013, 07:57 PM   #7
deverson's Avatar
Rewards Points: 77
My bad!!! Old romex not BX. Still won't pass inspection.
Old 05-29-2013, 09:02 PM   #8
Ok. We'll put in an outlet for the dishwasher tomorrow.
Old 05-29-2013, 09:04 PM   #9
Since the price is pretty much the same, I just took the 20 amp ones. I didn't think it would make any difference.
Old 05-29-2013, 09:43 PM   #10
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
you do not have to have the outlets or switches in for the ROUGH inspection .... they are or want to look at the wires/grounds ..
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-29-2013, 09:50 PM   #11
I know the ROMEX is grounded, so can I just leave it like this? Here is another picture I took:
Old 05-29-2013, 10:26 PM   #12
One of the best things you can do to prepare is call your electrical subcode official in advance of the inspection and discuss their expectations and how they would like to see things during the inspection. For example they may not want the receptacles installed so they can see the individual conductors and the ground wire. Keep asking questions on the forum as well you will get some excellent advice.
clydesdale is offline   Reply With Quote
Old 05-30-2013, 06:15 AM   #13
Rewards Points: 516
Attachment 71794
for the mot part they want to see the wires were they belong...
dishwashers and disopals are cord and plug now.. so you need a box mounted to land that wire in....
Old 05-30-2013, 08:58 AM   #14
JW
mm11's Avatar
Rewards Points: 596
Inspectors I've dealt with want to see the ground wires spliced together, with no devices in boxes, for a rough-in inspection.
mm11 is offline   Reply With Quote
The Following User Says Thank You to mm11 For This Useful Post:
Philly Master (05-30-2013)
Old 05-30-2013, 10:15 AM   #15
Rewards Points: 512
Attachment 71794
I would say that you should lengthen the conductors beyond the connectors. You want at least 6" of wire to work with. Just move the connector back about 1/4" so that there's a bit of cloth showing beyond the connector.
Installation is the Reverse of Removal.
Installing rough electrical porch light box RM575 Electrical 9 10-17-2012 04:42 PM
Rough in inspection matrix733 Electrical 4 10-29-2007 10:55 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 06:52 PM
Passed rough inspection, thank you! mt232 Electrical 1 06-13-2007 04:27 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 09:46 PM
