Old 04-26-2008, 11:15 AM   #1
Rough in Cabinet Lighting
I found a power source at the bottom of the base cabinets. I will be running 14-2 up to the counter top level and installing a switch. My question is:
1. Should I run the wiring from the switch to a junction box where all the wires from my cabinet lights will go? Or should I just run all the 14-2 into the switch?
2. I'm considering xenon and do I need to run 2 wires (one entering and one exiting) under each cabinet where I want light?
cibula11 is offline   Reply With Quote
Old 04-27-2008, 10:08 AM   #2
joed's Avatar
Your choice. Which ever version uses the least wire and doesn't create a box over fill situtation.
Low Voltage Cabinet Lighting Recommendations BigJimmy Electrical 2 01-20-2008 02:01 PM
Under cabinet lighting TonyD Electrical 20 11-08-2007 07:00 AM
Under cabinet linear lighting? kcrossley2 Electrical 1 07-08-2007 08:26 AM
under cabinet lighting handifoot Electrical 1 05-26-2006 12:48 AM
