-   -   rotating tv (http://www.diychatroom.com/f18/rotating-tv-159464/)
ncm21 10-08-2012 10:00 PM
rotating tv
I know this might not be the forum to ask this question but I figured I'd give it a try. I have a 30lb tv that I'm going to have drop down from the ceiling, but I need it to then rotate 90". I plan to attach it to a lazy susan bracket so it should rotate pretty easily, but I would like to motorize it somehow? Any ideas? Thanks
DannyT 10-08-2012 10:03 PM
is this a regular lazy susan? most lazy susans are made to support weight not suspend weight. if it spins what is gonna keep the wires from winding up on anything?
ddawg16 10-09-2012 01:19 AM
see if you can locate an old TV antenna rotator. Or, look at some of the ham radio sites....they should have some good info...
I have a remote rotator for my TV....the brand name is "Wife"...
JasperST 10-09-2012 08:04 AM
Have you done a search? They make mounts for that application:
http://www.amazon.com/s?ie=UTF8&keyw...kduckgo-ous-20
As far as motorizing it (if I was really determined to do it) I would look into some kind of hydraulic arm mounted to a bracket on the rotating piece. Extending it would turn it horizontal, retracting it, back to vertical. Or visa versa.
ncm21 10-09-2012 02:00 PM
It's a lazy susan bracket that supports 300lbs so I think it should be fine. And it only has to rotate 90 degrees back and forth, so wires won't wind up.
ncm21 10-09-2012 04:01 PM
This is the mount I'm using;
http://www.firgelliauto.com/download_file.php?file=22
But my trusses are running perpendicular to how I want my tv for viewing. So I need it to drop down and then rotate 90 degrees. I plan on attaching the t-bracket to a 2x4 or something and then attaching that to another piece of wood which will be mounted to lazy susan bearings. So I'd like to do some type of rotaty actuator with a belt drive or gears to rotate back and forth. Or use a linear actuator to push and pull back with possibly a pulley. That's what I'm looking for help on, how to motorize/rotate the lazy susan bracket.
Everet 10-11-2012 12:01 PM
Any chance you can post a photo of the "ceiling" location you are referring to AND a photo the "lazy susan bracket" would like to motorize?
All About Home Electronics.com
ncm21 10-11-2012 12:21 PM
It's just a standard 8' ceiling.
The bracket is from Amazon
http://ecx.images-amazon.com/images/...L._AA1500_.jpg
Everet 10-11-2012 02:44 PM
We've installed a few motorized TV lift cabinets in the past.
You might want to consider contacting a motorized TV lift manufacturer to see if they will either sell you the mechanism or tell you where you can buy the mechanism directly.
The reason I feel like this might prove to be a good direction to consider taking is because this mechanism is already designed to raise, lower and rotate the TV via remote.
The other consideration you would want to take into account is if the control module for a motorized TV lift mechanism has RF remote capability. If you get an IR TV remote system, which was standard with many units we worked with, you'll need to provide a direct line of site path to the IR receiver as opposed to the RF which won't need direct line of site.
I would think such a mechanism, by itself, would cost roughly in the high hundreds up to $1,200
