Old 10-08-2008, 05:40 PM   #1
Rope Lights/Telephone Wire Splicing
Two questions.....
I have built a riser for a home theater room where I wasnt to rope light around the bottom. I would like to just wire an outlet to a switch which I know is possible but I would like to run it to a dimmer switch. Is this possible?
Secondly, I need a phone line for this same room. The builder ran all phone lines to the box above garage which has a small entrance through the ceiling. I am 6'8" and 325 and will never fit in there. I have a number of outlets above this room which I will never use. I would love to either splice from the existing line upstairs and run it to the theater room. Is this possible?
Thanks in advance for your help!
will_53115 is offline   Reply With Quote
Old 10-08-2008, 05:55 PM   #2
dSilanskas's Avatar
[quote=will_53115;169789]Two questions.....
Question one - Is it possible yes, is it legal no haha
Question Two - Yes you can tap into an existing phone line
dSilanskas is offline   Reply With Quote
Old 10-08-2008, 09:46 PM   #3
My License Ain't 4 Sale..
Will, you can splice those phone wires til the roosters come home to milk. The dimmer is another matter because the code specifies that a dimmer cannot control anything but permanently installed lighting. This is meant to mean you can't control a receptacle with a dimmer. Is it dangerous? Not very. The problem is, you could severely damage some equipment by under volting it if you plug up to a dimmed outlet.
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
