Rope Light Made Of LED's - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 10:59 PM   #1
Rope light made of LED's
Are LED's connected parallel or series to assemble a rope light? What are the specs of the LED's to be bought if Im going to connect it on 220VAC?
Relax is offline   Reply With Quote
Old 10-25-2010, 04:31 AM   #2
Rewards Points: 1,192
Series-Parallel
bobelectric is offline   Reply With Quote
Old 10-25-2010, 07:17 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Bobelectric.,
Just becarefull in case the OP is not from North American due other area will have 230-240 volt line to netural so it may change the whole details a bit.
Merci,
Marc
Old 10-26-2010, 05:11 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,492
They are usually strings of series leds, all connectted in parallel.
so its a series / parrallel combination.
As for the ratings of the leds,
they are all different, with reguards to light output.
As for voltages most leds operate on simular voltages,
depending on color, usually 2.2v to 3.5v.
so you will have to experiment a bit,
to find out which leds to use,
but if you are really keen they are fixable.
if you have the time.
parts are easily available.
dmxtothemax is offline   Reply With Quote
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 03:48 PM
Rope Light Curtain Wiring Help! topec Electrical 4 08-10-2010 12:44 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Extend a circuit/draw power from light Ontario Electrical 3 03-23-2010 06:41 PM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 06:22 PM
