Room For A Tandem Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2011, 06:04 PM   #1
room for a tandem breaker?
I would like to get a small chest freezer for the basement, and I would like it to be on its own dedicated circuit. I have a QON 20-40MG200 panel, and some of the breakers were replaced with tandems by an electrician when our kitchen was remodeled. I would like to know:
(1) Is there still room for more tandems?
Also, how can I tell
(1) if a tandem will fit in place of a single and
(2) how many tandems are allowed in the panel (for future reference)?
Many Thanks in advance for the help!
pdxrain is offline   Reply With Quote
Old 10-02-2011, 06:29 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Usually there is a label inside the panel cover that shows the layout and where the tandem breakers can go. That panel designation leads me to think it is a 20 space , 40 circuit panel (meaning the tandems can go in any space.)
Coastal South Carolina
Old 10-02-2011, 06:35 PM   #3
Rewards Points: 324
tandems will go in all of the single pole breaker slots.you have a 20 slot 40 ckt panel.so if you want more 120 volt or a 240 ckt,change some single pole breakers to tandems to gain slots.
oleguy74 is offline   Reply With Quote
Old 10-02-2011, 07:43 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Just becarefull some of the QO panels with tandem breakers there are two verison one is CTL and other is Non CTL breakers.
The quickest way is check one of your tandam breaker and see if you have a cam finger below of the breaker that is CTL tandem breaker while the one sans cam finger is non CTL breaker.
There is a bit of price diffrence as well.
Your panel will have no issue take tandam breakers at all.
Merci.
Marc
Tags
tandem breaker
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 12:44 PM
Bad breaker? Ultrarunner2017 Electrical 6 02-19-2011 11:41 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 09:20 PM
Tandem Breaker 184 Electrical 3 05-06-2010 04:49 PM
Tandem breaker rusty_5620 Electrical 10 09-26-2007 04:03 PM
