Room For Expansion In Main Panel??? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 10:38 PM   #16
What kind of panel do you have?
jerseystyle26 is offline   Reply With Quote
Old 03-26-2011, 11:16 PM   #17
Registered User
Rewards Points: 5,516
Welcome to the forum!
Electrical work can be a life-taking work. If one has found they need a permit to continue, I suggest you follow through and get a permit. We can help you be safe, to a certain measure. You have to accept or reject some of the information you receive from here. I would hate to learn someone was hurt or killed from following the one advice that was solitary rather than the advice from the group. There are DIY'ers and professionals answering here, choose your actions wisely and safely. The Codes are the minimum safety standard, like getting a "D" on the test in school......
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
RST (03-28-2011)
Old 03-27-2011, 09:09 AM   #18
Rewards Points: 335
look at the very first thread, i have details there. are you after more information than that?
crankbait09 is offline   Reply With Quote
Old 03-27-2011, 09:52 AM   #19
Sorry I relized you did put dowb the info., the type of panel you have does support tandem(twin) breakers. According to you you have free space so you should be good to go.
Old 03-27-2011, 10:24 AM   #20
Licensed electrician
Rewards Points: 1,622
The part number posted is for the cover.
You are looking for a number formatted like this, QO12030M150.
Old 03-27-2011, 12:39 PM   #21
Rewards Points: 335
but the permit and inspection is standing in my way.......i realize everything else may be easy enough to do but i generally dont like to go against the rules........if i need a permit and inspection, then id feel better doing so.....
are these types of things expensive? (inspection/permit)
Old 03-27-2011, 01:24 PM   #22
All places are different. If your totally against not gettin a permit than get one. All I was pointing out in my experience when I do simple sidejobs as yours would be ive never pulled a permit. As long as the company/eletrician is fully insured/bonded any problems that would arise youll be safe. Only time we deal with permits is doing new construction and the homebuilder deals with the townships. Or if we work for a homeowner and do a rehab,service,addition.
Old 03-27-2011, 02:24 PM   #23
The OP is getting the permit like the OP should based upon the fact that he called the AHJ and they said one was required. End of story.
clydesdale is offline   Reply With Quote
Old 03-27-2011, 02:32 PM   #24
Rewards Points: 335
so are permits/inspections pretty expensive for something like this?
Old 03-27-2011, 02:40 PM   #25
In my town the fee would be $50. That would cover the addition of up to 25 outlets/fixtures. Service panels/entrances, sub-panels, motors, pools, would be more. Now if this was part of a renovation of a room that fee would probably be somewhere around $200-400 depending on the cost of the renovation as you would need to pull building and plumbing permits as well.
Old 03-27-2011, 06:02 PM   #26
I=E/R
a7ecorsair's Avatar
This will vary by location and the process put in place by the governing body. When I started my new house I got the building permit from the county and paid the county for it but I had to contact the state electrical inspector directly for the all required electrical inspections. I paid him a flat fee (to MN) that covered three trips - temp power, RI, and final.
a7ecorsair is offline   Reply With Quote
Old 03-27-2011, 08:48 PM   #27
Power Gen/RS Engineer
Rewards Points: 566
The cost in my jurisdiction is similar to Clydes: $50 for up to 25 outlets which includes RI, final and one re-inspection (if required) at no add'l cost. My local allows the HO to perform his/her own electrical work. I know that some do not allow this. Again, just check with your AHJ and post any follow ups for advice as needed.
Good luck and be safe,
J
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 03-27-2011, 08:55 PM   #28
Registered User
If a permit is required and the work was done by a licensed electrician without a permit, and something happens in the future to the house because of his visit, your Homeowners Insurance doesn't have to honor a claim. That would be an expensive lesson for someone......... just something to keep in mind.
Gary
Old 03-28-2011, 09:55 AM   #29
RST
DIY Homeowner
Rewards Points: 150
Get a permit, do it right!
Cost shouldn't be that much. It sounds like you don't have a lot of experience, and the process will insure that things are done correctly. Buy some books, read up, and come back here and ask more questions.
The danger with electricity is that you can completely screw it up but it will appear to work fine... until a fire or some other catastrophe occurs years later.
RST
RST is offline   Reply With Quote
Old 03-28-2011, 11:02 AM   #30
After reading this topic with interest, I think you should consider getting an electrician to do this for you. This is a relatively simple job and if you are having an issue understanding what is required to complete this task you should err on the side of caution and have a more knowledgeable person do the job.
If you decide to do it ask alot of questions and be safe, please.
A permit doesn't make you safe, it only makes sure the job is EVENTUALLY done correct.
screwy is offline   Reply With Quote
sub panel or main panel grounding dghowery Electrical 1 10-13-2010 09:18 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
