Room For Expansion In Main Panel??? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 09:31 PM   #1
Rewards Points: 335
room for expansion in main panel???
I have a 150A main panel in my home. The home was built in 1994. I would like to add an additional breaker for some new lighting i was planning on installing this summer. majority of the breakers in the panel are 15/1 or 20/1
How can i find out if i have enough room (load wise) to add more load to the panel without tripping the main breaker? Is this easy to do?
now, i am not sure if any of the existing circuits have enough room to add more load to them. how can i find that out? cause it may be easy enough to tie the new lighting in to an existing circuit (if theirs room)
Here are some specifics:
Square D
#QOC30U
Type 1
Series G1
150Amp Main
30ckt panel
6 spaces left
crankbait09 is offline   Reply With Quote
Old 03-25-2011, 11:10 PM   #2
Rewards Points: 6,652
List the breakers in the panel, and possibly post a picture showing same. Only way to know, would be to do a load calculation, and that means going through everything plugged in, or hooked up to the panel and adding up the numbers.
Old 03-26-2011, 07:47 AM   #3
Electrician
Rewards Points: 802
I'm probably safe to assume that by adding a few lights(i.e potlioghts, track lights, wall sconces) will not cause you problems. If there is room in your panel to adda nreaker just add another breaker.
darren is offline   Reply With Quote
Old 03-26-2011, 08:11 AM   #4
Electrical Contractor
kbsparky's Avatar
If your service is loaded to the point of tripping out the main with the addition of a couple of lights, you can't afford the electric bills!
-KB
Old 03-26-2011, 08:40 AM   #5
Rewards Points: 335
i will get this info today or as much as i can.
if i wanted to add a new breaker, do i have to have a permit to do so? is this an easy enough DIY that i dont need a professional to come in?
Old 03-26-2011, 09:01 AM   #6
Pulling a permit depends on how strict your local codes are. Check online at your City or County website, and you should be able to find out what scope of work, the home owner can perform without a permit. Our city is pretty lax when it comes to being able to perform your own electrical without a permit.
Old 03-26-2011, 06:29 PM   #7
Rewards Points: 335
it looks like i need a permit to add a breaker in to my house panel as well as having it inspected once complete.
i have never got a permit before or had a reason too, plus the inspection on top of that. i cant imagine its that cheap. what was supposed to be a quick fix/addition has turned in to being quite expensive.
Old 03-26-2011, 07:52 PM   #8
If your just adding a simple circuit and not doing major work I dont see yourself needing a permit.
jerseystyle26 is offline   Reply With Quote
Old 03-26-2011, 09:21 PM   #9
I believe that breakers are made to trip at 80% of there rating so your 150 Amp main would need 120 Amps drawn to trip it. Your main concerns would be Electric Stove, Dryer, Hot Water Tank, Furnace or other Larger breakers in your panel. If you are just adding lighting and plugs you should be ok, but err on the side of caution.
screwy is offline   Reply With Quote
Old 03-26-2011, 09:23 PM   #10
jbfan's Avatar
Rewards Points: 648
Not true! A150amp breaker will trip when the current is 150amps or more.
This pretty much for any breaker, with few exceptions.
Old 03-26-2011, 09:43 PM   #11
Rewards Points: 335
i actually contacted the permit place for my county. they told me i had to have a permit/inspection to add a breaker and any additional wiring........
Old 03-26-2011, 09:52 PM   #12
All municipalities are like this cuz they want to get paid. If youre only adding a simple circuit with a few lights,outlets,ect. Youll be fine without a permit. They wont know youre doing work in your own house. As long as youre not doin anything structual or an outdoors big noticable job your fine.
Old 03-26-2011, 10:04 PM   #13
Licensed electrician
Rewards Points: 1,870
Some jurisdictions do not even cover the costs of doing the inspection from the permit fees. Maybe they are concerned enough that they want the wiring checked to ensure the life safety of the current and future residents. Without the oversight how will an untrained person know that the work they did is safe? The Op might want to consider themselves lucky that they don't need a license to pull the permit.
Your attitude runs counter to the safe and compliant instructions that many professionals on this site give.
Old 03-26-2011, 10:27 PM   #14
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Just talked to my sparky about the same thing
No permit required.
If the panel doesn't have any spare slots, you can add a doubled up mini breaker.
It gives you two breakers in one slot.
tcleve4911 is offline   Reply With Quote
Old 03-26-2011, 10:31 PM   #15
No permit required.
Not all panels are listed to accept tandems. You need to check the panel label.
tcleve4911 (03-26-2011)
sub panel or main panel grounding dghowery Electrical 1 10-13-2010 09:18 AM
Main Panel / Service Upgrades gbe Electrical 12 11-06-2009 11:20 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Passing wire to another panel theatretch85 Electrical 5 09-20-2009 11:09 PM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 02:15 PM
