Rookie Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2009, 10:19 PM   #1
DIY Rookie
Send a message via AIM to jpfreak33
rookie question
So I am scared to death of electrical so this was a big deal for me. I am refinishing my office and replaced all the ivory outlets and switches with WHITE. so I killed the power and replaced everything, everything went great. I flipped the power back on and tested all the outlets and everything worked! One problem, The light switch operates one plug on one outlet and at the moment, that plug is always on, weather the switch is on or not. There was 2 black wires, one white and one ground to just that plus. I am now frustrated, I have broke wires off in 3 new outlets now trying to switch the wires around, I am loosing my nerves and running out of new plugs to try. Any suggestions??
jpfreak33 is offline   Reply With Quote
Old 01-31-2009, 10:38 PM   #2
Electrician
Rewards Points: 794
There is a tab in between the two hot screws, that will have to be broken. This allows the top half and bottom to work indivually on that plug.
darren is offline   Reply With Quote
Old 01-31-2009, 10:40 PM   #3
perpetualjon's Avatar
Rewards Points: 150
I think some pictures may help understand your situation. Can you snap a few of both the switch and the outlet in question?
perpetualjon is offline   Reply With Quote
Old 01-31-2009, 10:56 PM   #4
DIY Rookie
Originally Posted by darren View Post
There is a tab in between the two hot screws, that will have to be broken. This allows the top half and bottom to work individually on that plug.
I do not see what your talking about, let me say again I have not had any experience with this kind of stuff so this is all new to me
ok, couple others things worth mentioning, the switch did NOT have a ground wire connected when I removed the old one so I kept that off to keep consistent with what was there.
Old 01-31-2009, 11:00 PM   #5
DIY Rookie
Any reason why these wires are breaking inside the outlet when I go to pull them back out to switch things around? I didnt have a problem pulling the wires out of the old plug. Just operator error?
Old 01-31-2009, 11:02 PM   #6
There is no way to make it any more clear.
Use you needle nose pliers and pry the brass colored tab between the screws on the recep off.
Yeah...because they are not designed to be just pulled out. Think about it and understand the mechanism that holds the wires in place. If you pull them out, you compromise the connection and may cause a loose connection. Loose connections cause fires.
Switch should have the ground wire hooked to it in this case.
220/221 is offline   Reply With Quote
Old 01-31-2009, 11:27 PM   #7
Rewards Points: 150
On the receptacle (outlet) there are two brass colored screws and two silver colored screws. The two brass colored screws are connected via a connecting plate. This plate has a small tab in between the two screws. If you break this tab then the top half of the receptacle will be separated from the bottom half. The black wire from your switch needs to go to either the top or bottom brass screw. Which ever half you connect your switch wire to will be the one that you can control from the switch. You do not need to break the tab between the two silver colored screws.
Steelhead is offline   Reply With Quote
Old 01-31-2009, 11:35 PM   #8
Rewards Points: 150
I believe you may be attaching the wires to the receptacle by pushing them into the little holes in the back of the receptacle. If you are doing this you can not just pull them back out. You need to release them by pushing a small flat blade screwdriver into the slot next to the wire. Push in on this and pull the wire at the same time and it should come out.
Oh and if this is the way you are connecting the wires I recommend that you connect the wires using the screws instead. The screw method is much more safe and reliable.
Old 02-01-2009, 10:10 AM   #9
DIY Rookie
Sorry I dont want to sound ignorant, I wasn't sure if you were talking about the metal tab or the plastic tab, I know now that its the metal tab.
Perfect thanks!!
I was pushing the wires in the hole, I thought when I pushed them in the hole I was suppose to tighten them with the screw to make then snug, now I understand whats going on.
Thanks for everyone's help I think I can get it from here
Old 02-01-2009, 04:04 PM   #10
DIY Rookie
got it!
thanks guys, I also went out and bought a little 3light plug in tester and found out that I switch the hot wire on one of my outlets so I fixed that as well. Now I can start doing things I am better out, like building a desk for my office
Rookie DIY Question will_53115 Plumbing 4 01-15-2009 10:16 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
