Roofer Fatally Shocked From Overhead Wires. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2013, 11:37 AM   #1
Rewards Points: 512
Roofer fatally shocked from overhead wires.
This got me to wondering how, since the POCO's overhead wires are insulated (the ungrounded conductors, anyway), how this happens. It wasn't reported that any of the wires broke loose.
At any rate, this should serve as more warning for us electrical DIYers.
http://www.14news.com/story/23038392...-roofing-house
Installation is the Reverse of Removal.
Old 08-04-2013, 11:53 AM   #2
joed's Avatar
Rewards Points: 12,854
Not all wires are insulated, especially older services. Many times there are bare section near where the connections where made. A metal ladder could have scraped off the insulation.
The Following User Says Thank You to joed For This Useful Post:
sirsparksalot (08-05-2013)
Old 08-04-2013, 12:00 PM   #3
Oso954's Avatar
Rewards Points: 1,106
Your title is assuming a "fatal shock". It is just as likely that the two story fall was the fatal event.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
gregzoll (08-04-2013)
Old 08-04-2013, 02:43 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
The splices at the weatherhead are often very poorly insulated, or not at all. Also, the article doesn't say the shock was from the service entrance cables. Could have been contact with nearby primary, as often happens to painters and siding installers. Could have been random abandoned wires up there (old AC unit?). I had a commercial jobsite where someone had removed two rooftop units and left the cut-off flex whips laying on the flat roof. They were 480V 3ph, and hot! Looked like it must have made quite a show in the rain.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 08-04-2013, 05:18 PM   #5
Electrical Contractor
kbsparky's Avatar
Most medium and high-voltage distribution wires are NOT insulated. That is why they are mounted on insulators.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 08-05-2013, 06:57 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,346
Assuming that low voltage conductors are insulated (I don't believe so),
What condition was the insulation ?
If it's been out in the weather for a long time,
Then it's condition could well be poor.
Also banging into it with sharp edged roofing iron,
Would easily penetrate that insulation.
In Australia very little of the overhead conductors are insulated,
I would assume USA is simulair.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 08-05-2013, 07:05 PM   #7
PoleCat's Avatar
Rewards Points: 1,646
The original drops in my neighborhood are bare wire. Most have been updated but there are still quite a few of the OEM. My next door neighbor had them running through his oak tree and when it rained the light show was spectacular! I finally talked him into getting them replaced, freebie courtesy of Dayton Power & Light;
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 08-05-2013, 09:29 PM   #8
Lord of Slums
Rewards Points: 1,974
so what exactly happens to painters and siders? I ask, what should not by touched near a house, what are common electrical precautions to take?
mj12 is offline   Reply With Quote
The Following 2 Users Say Thank You to mj12 For This Useful Post:
agoodboy (08-05-2013), MTN REMODEL LLC (08-05-2013)
Old 08-05-2013, 09:39 PM   #9
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,758
DMX and Pole.... I have no experience with these conditions/situations....
Just curiosity.... how are the wires/servoices held apart from each other.... just a safe distance as strung, or with some kind of insulator for standoff????
Tia
MTN REMODEL LLC is offline   Reply With Quote
Old 08-05-2013, 10:14 PM   #10
Painters and siders often use long poles or handle long pieces of material. Where primary (high voltage) lines run near a house, they can accidentally contact a line with something. The result is always horrible. This is not as much of a risk in most newly built areas, but old buildings were often constructed with less clearance from power lines. The wires from the utility to the house are only 120V, so not as much of a hazard as the 7200V primary but still responsible for many injuries and deaths. A mild shock on a rooftop can cause a fatal fall. Anyone who is not electrically trained should stay well clear of all overhead wires. They are not reliably insulated, as a rule.
Old 08-05-2013, 10:16 PM   #11
Tia
Safe distance apart !
Stand off's usually only used in windy or cyclone prone area's
Old 08-05-2013, 10:19 PM   #12
Electrical Enthusiast
Rewards Points: 504
Tia
In my area, older bare wire services are simply held further apart. It's like the two 120 legs plus the neutral you see feeding street lights, except further apart.
Kyle_in_rure is offline   Reply With Quote
The Following User Says Thank You to Kyle_in_rure For This Useful Post:
Old 08-05-2013, 11:01 PM   #13
Rewards Points: 512
Yes, you are correct; that doesn't, however, answer the full scope of my post.
The Following User Says Thank You to sirsparksalot For This Useful Post:
Old 08-05-2013, 11:09 PM   #14
Rewards Points: 512
I was thinking of the lines from the pole to the weatherhead. I've cut and restored several of these for service upgrades, using split-bolt connectors. And they are always insulated, except, of course, for the neutral.
Depending on our POCO to come out and restore anything is usually an exercise in futility.
Old 08-05-2013, 11:35 PM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
The report is lacking some information, but as one poster said, it sounds like maybe the fall is what killed him.
That's assuming he caught the low voltage wires going to the house.
I would be really surprised if he was able to reach the medium voltage wires.
When I built my garage...I wanted to push it back to the property line....one of the topics came that came up...because my garage is 2-story...they wanted to make sure no one could touch the medium voltage lines from the roof of the garage...I believe the min distance is 8'.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
