Romex Under The House? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-20-2007, 11:24 AM   #1
Romex under the house?
Can I run type NM cable fastened to the floor joists under the house? I think somebody once told me that that is considered a wet or damp location.
Doug_Shaver is offline   Reply With Quote
Old 06-20-2007, 11:46 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
It is not prohibited by the nec, however local rules may apply
Old 06-20-2007, 11:53 AM   #3
Thank you very much.
Old 06-20-2007, 03:57 PM   #4
Master Electrician
JohnJ0906's Avatar
Basement? Crawl space? IS it damp?
If you secure to the undersides of the joists, don't run it out in the center. Run them as close to a wall, duct, etc, so in the future no one tries to hang anything from the wire. Drilling holes or using a running board is better, IMO.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 06-20-2007, 04:19 PM   #5
weekend warrior
Rewards Points: 150
drilling holes in your beams is better than staples?
johnny331 is offline   Reply With Quote
Old 06-20-2007, 04:35 PM   #6
Master Electrician
JohnJ0906's Avatar
Depends.
A PROPERLY drilled hole isn't going to weaken anything. It gets the wires up and out of the way.
It's a little hard to see exactly where he's running these wires!
John from Baltimore
One Day at a Time
Old 06-20-2007, 10:03 PM   #7
It's a crawl space.
IS it damp?
I'm in Southern California. Normally, not even the rivers are damp.
Seriously, it does stay dry there, even when it rains.
Old 06-21-2007, 04:39 PM   #8
Master Electrician
JohnJ0906's Avatar
IMO, you are OK with the romex, and with stapling to the undersides of the joists. At least, I know it would fly here. I know CA may have different rules.
John from Baltimore
One Day at a Time
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 05:54 PM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
