Romex Thru Block Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2014, 07:49 AM   #1
Rewards Points: 877
Romex thru block wall
I am placing a conduit thru block wall that is soon to me filled with concrete. For the future AC unit I want to run romex from box and go thru the block wall just behind unit. The block and brick together will be twelve inches thick. Can I stub thru wall with a one inch diameter grey pvc conduit about 12 to 13 inches long with a male adapter on both ends. The outside male adapter will connect to the disconnect box and the 8 ga romex for the 1 1/2 ton split unit will go from the inside stud walls thru block/PVC conduit to unit disconnect on outside brick wall. Is this the best way to do this and will it comply with codes?
JM
ddsrph is offline   Reply With Quote
Old 08-20-2014, 08:20 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
I wouldn't put a male adapter on the inside unless you plan on installing a box.
Are you sure your unit requires #8.
Don't forget the service receptacle within 25' of the unit.
The Following User Says Thank You to jbfan For This Useful Post:
ddsrph (08-20-2014)
Old 08-20-2014, 08:56 AM   #3
Master Electrician
Rewards Points: 3,964
I would use car flex.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
ddsrph (08-20-2014)
Old 08-20-2014, 09:51 AM   #4
Rewards Points: 877
The wire size could possibly be a 10 ga. It will only be a 1 1/2 ton unit and only about 20 feet from main panel. The cut off box will be within three or four feet of the unit. If I don't put a male adapter on the inside can the sharp edge of the plastic conduit be a problem for the romex? Is carflex the flexible weather proof conduit?
JM
Old 08-20-2014, 10:34 AM   #5
Master Electrician
JM
Yes. LFNC. Liquid tight flexible non-metallic conduit. There are different brand designations for the product. If you put it through the wall it can be easily cut to size and flexed into the bottom of the disco.
ddsrph (08-20-2014)
Old 08-20-2014, 10:35 AM   #6
Licensed electrician
Rewards Points: 1,880
You can probably use #12. There is no way you need #8.
ddsrph (08-20-2014)
Rigid XPS to block wall bluefoxicy Insulation 11 12-19-2013 09:07 PM
Filling Concrete Block Cells to Repair Wall Wildbill9000 Concrete, Stone & Masonry 1 08-29-2012 06:39 PM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 03:07 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
