Romex - Through Or Under Joists? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2009, 09:49 AM   #1
Rewards Points: 109
Romex - through or under joists?
I am finally getting around to running wires for my steam shower generator, floor hear and bathroom GFCI. I was flipping through a code book this morning and theres a picture which shows running 8/3 through the joists and >=8/3 stapled under. But I couldn't find anything in wording which described it.
Is there something in code against running larger cables through the joists? In case of my steam unit I am running 6/2.
BimmerRacer is offline   Reply With Quote
Old 04-21-2009, 10:35 AM   #2
Licensed electrician
Rewards Points: 1,020
There is no prohibition against it. The picture was probably just trying to show that larger cables are allowed to be secured under the joist in an unfinished basement.
In order for that to be done you need to be no smaller than 2 #6 or 3 #8s. The Code Article is 334.15(C).
Old 04-21-2009, 10:47 AM   #3
Rewards Points: 109
Cool, thanks for the reply. As much as it is easier to run them under, I would really like to get rid of the ugly ceiling tiles and in part of the basement.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 07:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
Spacing of ceiling joists Pineconeman Building & Construction 3 05-14-2005 12:16 AM
