Romex Through Brick To Outside Outlet, Conduit Needed? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2012, 12:11 PM   #1
mtk
Rewards Points: 16
romex through brick to outside outlet, conduit needed?
Hi, I want to install an outside outlet (GFCI with in-use cover). My house is brick construction (*not* stick with brick veneer). Where the Romex passes through the brick, should it be in conduit? Or is it OK to just put the romex through the hole, and then use a nm connector to the box?
The box will be surface mounted on the brick outside.
mtk is offline   Reply With Quote
Old 08-28-2012, 12:48 PM   #2
Licensed electrician
Rewards Points: 1,622
No conduit is needed. You could use conduit as a sleeve if you wish.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
mtk (08-28-2012), stickboy1375 (08-28-2012)
Old 08-28-2012, 03:55 PM   #3
mtk
Rewards Points: 16
Thanks Jim!
Old 08-28-2012, 05:14 PM   #4
Rewards Points: 2,516
Yeah definitely sleeve it
hammerlane is offline   Reply With Quote
Rigid conduit installation help needed socalsteve72 Electrical 35 03-20-2012 11:36 PM
Joining romex and conduit Restyle Electrical 2 11-08-2011 03:01 PM
Secure Wires from Conduit in Sub Panel brgmgb Electrical 7 09-29-2011 09:10 PM
Running ROMEX into Conduit tlj Electrical 15 11-05-2009 07:20 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
