Romex With Thin Grounding Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-10-2009, 05:24 PM   #16
Rewards Points: 820
this thin wire is not the ground. The BX sheath is.
Not true!
According to another thread on this forum;
Ground tester?
Read the 2nd post in the thread, by Chris75.
"If your old BX wiring does not contain a bonding wire then you cannot use the jacket as a grounding path to begin with and only two wire receptacles can be used, or the receptacles need to be gfci protected."
So, you need that bonding wire inside of the BX in order for the cable to be considered grounding.
Ultrarunner2017 is offline   Reply With Quote
Old 01-10-2009, 09:40 PM   #17
Originally Posted by KE2KB View Post
Not true!
Ground tester?
Well, you need the strip present, just wrap it around the back when your done with the connector. You don't actually "use" it. It is there to lower the resistance of the jacket.
How you can prep bx
http://www.diychatroom.com/showthrea...659#post210659
rgsgww is offline   Reply With Quote
how to wire romex to 2 3 ways to a half hot receptacle smoothinstall Electrical 3 11-30-2008 11:56 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 01:42 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
