Romex With Thin Grounding Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 08:08 PM   #1
romex with thin grounding wire
I am rewiring our house with 12 gauge romex. Most of the old wiring is woven two wire but some is 12/2 romex but with a smaller gauge ground wire. Should I replace that also?
John
dogbone is offline   Reply With Quote
Old 01-08-2009, 09:08 PM   #2
Rewards Points: 2,350
John
There's really no reason to go out of your way to replace it, but if you are rewiring the whole house, then what's the difference in cost? Might as well.
Old 01-08-2009, 10:31 PM   #3
Rewards Points: 900
Must be very old NM. I can't recall ever seeing any with a smaller ground wire.
Ultrarunner2017 is offline   Reply With Quote
Old 01-08-2009, 10:41 PM   #4
There was a period in the 60s or 70s when 14-x and 12-x had a 16 gauge ground. Like I said, I wouldn't go tearing walls out just to replace it cause in reality it will still allow enough current to flow to operate the OCP but if I was rewiring anyway, might as well change it.
Old 01-09-2009, 10:08 AM   #5
Rewards Points: 900
I guess a thin grounding wire is better than the sheath of old MC.
I can't tell you how many places I have found old MC that has not been properly terminated in the clamp, causing circuit to lose its ground.
Old 01-09-2009, 11:39 AM   #6
Thanks for the replies. Yes, I think it is 1960's wire. I suppose I might as well replace it while I am at it. Hmm...I was born in 1953, I guess I am getting closer to being replaced too.
Old 01-09-2009, 11:54 AM   #7
The old mc (called "bx") has to have a bonding strip to use it as a ground. The only bx I've seen with bonding strips is the bx from the late 50's-60's.
Code back then required a ground to the box even though they didn't have grounded outlets. Thank god they did that...makes it so much easier.
rgsgww is offline   Reply With Quote
Old 01-09-2009, 02:48 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Depends on you have a thin ground wire or not!
jbfan is online now   Reply With Quote
Old 01-09-2009, 06:19 PM   #9
Rewards Points: 900
I've got a lot of that BX in my basement. Also have the very old MC in the walls throughout the house.
The BX has the thin bonding wire, but it invariably breaks off whenever I try to do anything with it.
So far as I have tested, I still have grounding throughout the house, but my tester doesn't put a load on the ground, so I don't know whether it's really grounded.
Perhaps I should buy/build one that does.
Old 01-09-2009, 06:20 PM   #10
Rewards Points: 900
Hey guy; I'm right behind you. 1955.
Old 01-09-2009, 06:34 PM   #11
1955! That's the year of the famous Hill Valley lightning storm.
Old 01-09-2009, 09:39 PM   #12
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
In my house,built in 1963. There were a couple circuits run with romex 12-2 WITHOUT any ground wire. The rest of the romex has undersized grounds (16gage I believe).
I only went out of my way to replace the cables that were not ground. I put in EMT and THHN to replace that!
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-09-2009, 11:43 PM   #13
My house was built in 1960, has all bx (except for new additions/rewire) It has "GE" stamped all over it and when spliced, smells like old anti oxidant or something.
Old 01-10-2009, 11:29 AM   #14
Good one jbfan. > : )
Old 01-10-2009, 02:24 PM   #15
Remodeling Contractor
this thin wire is not the ground. The BX sheath is.
how to wire romex to 2 3 ways to a half hot receptacle smoothinstall Electrical 3 11-30-2008 10:56 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 12:42 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
