Old 10-13-2012, 10:13 PM   #1
romex termination - plastic box
i bought a carlon A615DEL plastic (octagon) box which has 4 knockouts for termination.
i need to terminate 14-2 romex in this box.
the question is - what kind of cable clamps are approved for this box?
looking at the carlon literature, i could not figure out if this box can be used with 3/8" twin screw clamps i normally see on metallic boxes
is this box to be used only with ENT conduit system?
drgkjd is offline   Reply With Quote
Old 10-13-2012, 10:58 PM   #2
Electrical Contractor
You could use a 1/2 inch cable clamp, or you could use a plastic push in connector.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 10-13-2012, 11:41 PM   #3
thanks jbfan
How do you seal plastic overflow drain hole on bathroom sink? stouto Plumbing 12 12-24-2011 11:16 AM
Chrome paint on plastic Thurman Painting 3 08-24-2010 01:17 PM
Basement Sump Pump & Dimpled Plastic Membrane Interior Questions cloves Building & Construction 0 03-24-2010 10:44 PM
Carlon B121adj Plastic Box Cable Clamping SS396 Electrical 10 01-15-2009 09:01 AM
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 10:07 AM
