Romex In PVC - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 01:40 PM   #1
Romex in PVC
What's the electrical code for running romex within PVC? I remember reading that it's not allowed due to the heat it causes.
So my question is, can I run romex in pvc?
ItsDaveTime is offline   Reply With Quote
Old 07-09-2012, 02:03 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ItsDaveTime View Post
...can I run romex in pvc?
Only for very short runs (like to protect it).
If the intention is to add a circuit somewhere that romex is inappropriate
then use wire in conduit or (if underground) UF rated wire.
Old 07-09-2012, 02:05 PM   #3
Adding an outlet for a refrigerator in the garage, tying into the existing garage door outlet. Running romex in the attic, but was going to utilize pvc down the interior garage wall, probably 4' of pvc.
Old 07-09-2012, 02:14 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Why not snake it down the wall and cut in a box?
Old 07-09-2012, 02:20 PM   #5
It's a concrete poured wall (garage wall), so snaking it down it fairly impossible.
Old 07-09-2012, 02:41 PM   #6
MarginallyQualified
Adding an outlet...Running romex in the attic, but was going to utilize pvc down the interior garage wall, probably (the last) 4' of pvc.
I've seen worse than that done without it blowing up.
Old 07-09-2012, 02:59 PM   #7
Oh, you said interior wall so I assumed framed.
Just keep in mind, Sch40 PVC affords no more protection than NM cable in the eyes of the code.
Old 07-09-2012, 03:01 PM   #8
So what would your recommend? Run individual strand down pvc to the outlet, or just go with the romex in a 1/2" pvc down the wall? I can always just run the romex down the wall on its own I suppose. It's just in the garage, so would there be any issue with that?
Old 07-09-2012, 03:04 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,858
Definitely OK. You can run NM cable (romex) in conduit all you want, as long as the conduit is not in a location where NM cable isn't allowed. The conduit would be classified as a "sleeve", not a "raceway", under these circumstances. There is no heat problem - the same derating rules apply as if you had individual conductors in the conduit.
mpoulton is offline   Reply With Quote
Old 07-09-2012, 03:05 PM   #10
Good news. Thanks for your help. Can't wait to get into the hot attic here in South Florida to get this done.
Old 07-09-2012, 04:28 PM   #11
Licensed electrician
Rewards Points: 1,028
Unless the cable is fished, be sure to secure it within 12" of the end of the sleeve. Use a bushing at the ends of the sleeve, or the proper fitting where it goes into the box.
Be sure to ground the box also.
3 wire romex to electrical panel and GFI? dvarga Electrical 16 05-17-2012 10:32 PM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
