Romex In PVC - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 06:06 PM   #1
Rewards Points: 1,214
Romex in PVC
Is it OK to run romex in PVC in a basement ? Heard from an Electrican it's OK.
COLDIRON is offline   Reply With Quote
Old 09-27-2011, 06:10 PM   #2
Electrical Contractor
kbsparky's Avatar
Yup..
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
COLDIRON (09-28-2011)
Old 09-27-2011, 07:28 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Why would you want to?
Old 09-27-2011, 07:36 PM   #4
Code05's Avatar
Rewards Points: 1,104
Pipe fill with cables is a PITA.
Code05 is offline   Reply With Quote
Old 09-28-2011, 06:45 AM   #5
" No need to answer my question has been answered by KB".
Old 09-28-2011, 06:47 AM   #6
"I Know".
Old 09-28-2011, 06:48 AM   #7
That simple huh?
OK then. Good luck.
Old 09-28-2011, 06:50 AM   #8
That simple huh?
OK then. Good luck.
" No need to answer that either".
Old 09-28-2011, 08:25 AM   #9
Had a stupidvisor years ago that would not buy anything except for romex. He would want us to run 8/2 through 1/2" carrflex. Yes..it will eventually fit. Enough j lube, cuss words, and benditwisting you can do it. Thankfully the guy got fired before we could corner him and beat him with the carrflex.
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
gregzoll (09-28-2011)
Old 09-28-2011, 09:00 AM   #10
Look guys here's the deal, 12-2 already ran around cinder block room in basement with outlets every so many feet apart, job is real neat going around the wall to each outlet, and PVC painted to match room. Everything complete just asking the question because heard from some it meets code and other's not code. Just an FYI question not a major problem. Never stated it was my job or not. Thanks.
Old 09-28-2011, 11:07 AM   #11
Rewards Points: 6,652
ColdIron, I only use emt from the outlet up to the ceiling joists, to help protect the romex from damage in my basement. I have my outlets sitting aprox four feet from the floor, so if there is any flooding, they are up far enough. Unless it totally floods, which I do not see happening, due to I am on the top of a hill, and everything at the bottom tends to flood.
The Following User Says Thank You to gregzoll For This Useful Post:
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 06:55 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
