Romex Per Holes In Wooden Framing - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 08:42 PM   #1
Rewards Points: 79
Romex per holes in wooden framing
How many 14/2 or 12/2 romexcan you run through 3/4" holes drilled thrugh wooden framing?
Thanks,
Eric
Ebierley is offline   Reply With Quote
Old 02-06-2013, 08:45 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
You'll get conflicting answers to this, but the bottom line is you can pull up to four cables, sized #14,#12 or #10, through a bored hole before you have to worry about derating.
Old 02-06-2013, 08:48 PM   #3
Rewards Points: 1,192
No derating until 24 ".
bobelectric is offline   Reply With Quote
Old 02-07-2013, 08:06 AM   #4
Resi EC
Rewards Points: 252
Both Speedy and bob are correct, however, in my neck of the woods my inspectors only like to see two romex per hole. (irregardless of hole size or wire size)
They don't go on the derating, they go on bundling, may want to check with your local building division before you have to re-do something.
Gac66610 is offline   Reply With Quote
Old 02-07-2013, 08:28 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm curious why the building code would determine how many cables can go thru the hole. I would think the size of the hole would matter to the building dept, but not the number of cables.
Old 02-07-2013, 08:41 AM   #6
Resi EC
Rewards Points: 252
I know, and have argued, but to no avail.
I am use to it now, and I tell them (jokingly), when drilling through joists I don't mind weakening the structure.
Found this on another forum, interesting read.
http://www.copper.org/applications/e...ion_report.pdf
Old 02-08-2013, 02:06 PM   #7
Rewards Points: 1,426
Irregardless is not a word. I hear people use it all the time and it would be rude to tell them in person. Since we're on a forum, I thought I'd mention it. People who realize this tend to giggle at people who use it. Kind of like saying for all intensive purposes instead of intents and purposes.
People will argue it's a word, but I avoid it anyway.
mikegp is offline   Reply With Quote
Old 02-08-2013, 02:32 PM   #8
Explain this please?
I know what is ment by derating. But not until 24 ".
Hardway is offline   Reply With Quote
Old 02-08-2013, 04:24 PM   #9
I always laugh when folks say "my inspectors like to see".
I don't give a crap what they "like" to see.
What is the code? Is it open to interpretation? THAT is what they can see, NOTHING more.
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (02-09-2013)
Old 02-08-2013, 05:16 PM   #10
Resi EC
Rewards Points: 252
yeah, I know
But, I personally can't see pulling 4, 10-2 w/g through a 7/8" hole.
It's tough enough just getting 4, 14-2 w/g.
If we do everything to code why have inspections?
He also believes that in larger homes with more than 2 bathrooms, it should be split into two different circuits. It was only a suggestion, but that and kitchens will have the larger loads.
Maybe we should never listen to inspectors, they're not the ones that will have to fix it anyway.
I didn't realize grammar was a prerequisite of electrical work, I'll make a guess that not all of us are collage graduates. So please forgive my ignorance
Old 02-08-2013, 05:20 PM   #11
What in the hell are you running FOUR 10/2's to in a house??
Old 02-08-2013, 05:37 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks,
Eric
IF the hole isn't being firestopped, as many as you like... if it is being firestopped, then you have to be concerned about 9 current carrying conductors per hole.
As a rule of thumb, i generally stick to 3-4 cables per hole, depending on straightness of holes and other variables.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
electures (02-09-2013), NJMarine (02-08-2013)
Old 02-08-2013, 05:42 PM   #13
Resi EC
Rewards Points: 252
2 - water heaters
1 - heat pump
60a, 30a 15kw furnace
But mainly I was going off your post
Old 02-08-2013, 05:58 PM   #14
2 - water heaters
1 - heat pump
Ooooo. OK.
Old 02-09-2013, 07:08 PM   #15
Rewards Points: 948
I also would like an elaboration
Toller is offline   Reply With Quote
Romex in Conduit Outdoors starrapido Electrical 3 11-27-2012 11:00 AM
Replace old Knob and Tube with Romex stevefrench Electrical 13 10-04-2012 07:59 AM
Romex on basement wall to panel iceclimber2001 Electrical 3 08-13-2012 08:40 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
