-   -   Romex laying across joist in attic? (http://www.diychatroom.com/f18/romex-laying-across-joist-attic-3512/)
Doug Crf 08-16-2006 04:02 PM
I have been doing alot of work up in my attic.
I am wondering about stepping on the romex.
Is it not a good idea?
There is tons of insulation up there so I can not tell
where the romex is laying.
Could stepping on it time and time again start to chafe it
or start to ruin it ia a way that could be a safety hazard.
Thanks Doug
jwhite 08-16-2006 04:16 PM
Yes you can hurt the romex. and if the attic is used for storage or any wires within 6 feet of the enterance no matter what are supposed to be protected by running boards.
J187 08-17-2006 01:44 PM
isn't all cable run in walk up attics supposed to be drilled into framing members 2" from edge?
jwhite 08-17-2006 02:57 PM
I don't know where you got the 2 inches from. It is the same 1 /14 as with a stud. and you can use running boards in an attic instead.
Also they do not need to be protected if they are further than 6 feet from a scuttle opening. For walk up attics if there is a sloped roof it gets tricky. The nook where the roof like meets the side of the house may not be considered tall enought to be practicle storage/ crawl space. It is up to the inspector to decide if this area needs running boards or not.
J187 08-17-2006 05:53 PM
I think you meant 1 1/4" right? I don't know where I got the 2 from, just thought that's what I read. Maybe 2" was a recommendation for framing members.
