ROMEX HomeRun Specifications - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 03:43 PM   #1
I want to run a new circuit from the service panel to a bathroom which is two floors above. I would like to use Romex. At a local Home Depot on two separate occasions, the salespeople advised me to use BX instead. One told me "it is stronger" (no argument there), another told me "it offers better protection against rodents" (!!??) I would imagine anyone with such an infestation would be better off investing in pest control before electrical.
Anyhow, is anyone familiar with New York, specifically, New York City electrical code as far as Romex in terms of home-running it from a service panel ? Thanks.
nixplix is offline   Reply With Quote
Old 04-17-2010, 05:48 PM   #2
joed's Avatar
Rewards Points: 12,918
Normally I would say use NM cable. But NYC has some special rules. NM used to be banned but I think they have made some changes to the code. You will have to wait for someone with NYC code info to confirm what is allowed. The home run has nothing to do with it.
Old 04-17-2010, 05:49 PM   #3
Civil Engineer
Rewards Points: 4,790
Back in the days when I lived in New York City, which is over 30 years ago, BX was required on the theory I suppose that rats could not chew through BX. I have no idea what the current rules are, maybe NY has reached the 20th century by now and allows Romex, but you best check with the electrical inspector. Unless of course you plan to do this without a permit, in which case why are you asking about the rules anyway?
Daniel Holzman is online now   Reply With Quote
Old 04-18-2010, 09:42 AM   #4
Just call me Andrew
Rewards Points: 1,020
Just found this in the NYC code on their website. I think this is from 1999.
http://www.nyc.gov/html/dob/html/model/oldcode.shtml
http://www.nyc.gov/html/dob/downloads/pdf/elamend.pdf
Originally Posted by NYC Code
336-4. Uses Permitted. Type NM, Type NMC, and Type NMS cables shall be
permitted to be used in the following:
(1) One- and two-family dwellings
(2) Multifamily dwellings, except as prohibited in Section 336-5
(3) Cable trays, where the cables are identified for the use
FPN: See Section 310-10 for temperature limitation of conductors.
(a) Type NM. Type NM cable shall be permitted for concealed work in normally
dry locations. It shall be permissible to install or fish Type NM cable in air voids
in masonry block or tile walls where such walls are not exposed or subject to
excessive moisture or dampness.
(b) Type NMC. Type NMC cable shall be permitted as follows:
(1) For concealed work in dry, moist, damp, or corrosive locations
(2) In outside and inside walls of masonry block or tile
(3) In a shallow chase in masonry, concrete, or adobe protected against nails or
screws by a steel plate at least 1/16-in. (1.59-mm) thick, and covered with plaster,
adobe, or similar finish
24
(c) Type NMS. Type NMS cable shall be permitted for concealed work in
normally dry locations. It shall be permissible to install or fish Type NMS cable
in air voids in masonry block or tile walls where such walls are not exposed or
subject to excessive moisture or dampness. Type NMS cable shall be used as
permitted in Article 780
Andrew
secutanudu is offline   Reply With Quote
Old 04-18-2010, 02:22 PM   #5
Thank you for the intel.
Tags
romex service panel
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
How to maintain clearance between romex and duct in joist bay? TomServo Electrical 8 10-24-2009 02:31 PM
Connecting Romex at Panel Bocolo Electrical 14 02-21-2009 05:55 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
