Old 10-28-2010, 11:50 PM   #1
romex holes close to edge
I am running some additional wiring, I discovered in the original wiring the holes were drilled aproximately 1.5" from joist edge code is 2" house is 30 years old was code different then?
artmark is offline   Reply With Quote
Old 10-29-2010, 12:01 AM   #2
Xtreme DIY'r
Who said the code is 2" ?
Impossible to get a hole 2" from each edge on a 2x4 today
Old 10-29-2010, 12:18 AM   #3
joists not studs they are 2x10
Old 10-29-2010, 12:25 AM   #4
Professional Wood Shafter
ryanh's Avatar
They where probally just drilled in a rush, i doubt theres any house that has every single hole drilled property..
ryanh is offline   Reply With Quote
Old 10-29-2010, 07:54 AM   #5
Licensed electrician
The code calls for the holes to be no closer than 1 1/4" unless nail plates are provided.
Drilling holes close to either edge of a joist will weaken it. The holes should be drilled in the middle of the depth of the member.
Old 10-29-2010, 10:04 AM   #6
fix it leave it? when I drill additional holes in the same joist in the same or height follow code?
Old 10-29-2010, 10:15 AM   #7
I certainly would not continue to drill in the spots that will take even more strength out of the joist.
The only way to fix this would involve adding sister joists to the existing framing. You would also need to remove the cabling to allow the sisters to be installed.
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
Drip edge mattflytx Roofing 3 09-09-2007 11:53 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 07:21 AM
