-   -   romex holes close to edge (http://www.diychatroom.com/f18/romex-holes-close-edge-85172/)
artmark 10-28-2010 10:50 PM
I am running some additional wiring, I discovered in the original wiring the holes were drilled aproximately 1.5" from joist edge code is 2" house is 30 years old was code different then?
Scuba_Dave 10-28-2010 11:01 PM
Who said the code is 2" ?
Impossible to get a hole 2" from each edge on a 2x4 today
artmark 10-28-2010 11:18 PM
joists not studs they are 2x10
ryanh 10-28-2010 11:25 PM
They where probally just drilled in a rush, i doubt theres any house that has every single hole drilled property..
Jim Port 10-29-2010 06:54 AM
The code calls for the holes to be no closer than 1 1/4" unless nail plates are provided.
Drilling holes close to either edge of a joist will weaken it. The holes should be drilled in the middle of the depth of the member.
artmark 10-29-2010 09:04 AM
fix it leave it? when I drill additional holes in the same joist in the same or height follow code?
Jim Port 10-29-2010 09:15 AM
I certainly would not continue to drill in the spots that will take even more strength out of the joist.
The only way to fix this would involve adding sister joists to the existing framing. You would also need to remove the cabling to allow the sisters to be installed.
