Romex As Ground Conductor? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 11:44 AM   #1
Rewards Points: 894
Romex as ground conductor?
Hi;
I am installing a VHF Amateur radio antenna on the side of my house.
I was shocked to find that #6AWG THHN would cost me 0.80/ft, and HD didn't have any bare copper conductor.
What would you think of using NM Romex cable with all three conductors tied together as the ground for the antenna.
Considering I paid only about $25 for 250ft 14/2 Romex, that would be a whole lot cheaper.
I realize that running NM (not UF) on the outside of the house is not code, but considering that this would be a ground conductor only, I don't think it really matters.
I'm going to keep looking for less expensive ground conductor, but in the mean time, what do you guys think of my idea?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 05-28-2009, 01:41 PM   #2
How many feet do you need?
If money is that tight you can find someone to sell you some scrap.
Hell I'd GIVE you some scrap just for the satisfaction of knowing that a job was done with some degree of professionalism.
220/221 is offline   Reply With Quote
Old 05-28-2009, 02:25 PM   #3
Rewards Points: 894
I need about 50 ft to get from the antenna mast to the SE ground at the electrode.
I'm going to check my local electric supply, as someone said HD often has great prices on Romex, etc only to make it up by fleecing you for THHN and similar.
I'll also check Ebay.
FW
Old 05-28-2009, 03:48 PM   #4
I might have over reacted.
Seriously, use the romex. It's copper wire, What's the worst that can happen? Maybe someone will take a pic and post it here
Just strip the conductors insulation a few inches and twist em together.
Old 05-28-2009, 03:58 PM   #5
Registered User
Termite's Avatar
This is for grounding a fault (lightning, specifically). If three separate conductors were a good idea it would be done all the time. I'd think that the fault current will not necessarily distribute itself evenly over the three grounding conductors on its way to ground, and the individual conductors aren't going to be able to handle it.
I say why risk it.
Old 05-28-2009, 04:06 PM   #6
Rewards Points: 894
I say why risk it.
I think you have a point. Under static conditions, where the current does not exceed the ampacity of the combined conductors, there should not be a problem combining separate conductors. But, with lightning, the actual current may well exceed the ampacity of the combined conductors, and heating plus resistance of the twist could, at least in theory cause an imbalance of current between conductors.
In reality, I am allowed to use up to #10 copper for the ground conductor of the antenna. I have set my mind on #6, because I think it is what is recommended, and most often used by Amateur radio stations.
If I can find a reasonable price on #6, I will certainly use it.
I am currently strapped for cash, having already spent enough on the project, but I won't complain about the difference in cost of #10 or #6, as long as I can get a decent price on it.
I think HD's price of 0.80/ft is robbery.
FW
Old 05-28-2009, 04:47 PM   #7
Rewards Points: 2,350
Here's a thought. And I'll probably get reamed for this but, if you are so strapped for cash, maybe you could buy five sticks of 1/2" EMT and use them for the ground? Put a ground clamp at each end and use a short piece of #6 to make the connections.
OK, I'm ducking...
Old 05-28-2009, 04:56 PM   #8
Rewards Points: 894
EMT isn't so cheap. Maybe 1/2" would actually come out less expensive than 50ft of #6, but of course it is not practical.
FW
Old 05-28-2009, 05:35 PM   #9
Originally Posted by fast1 View Post
hmm wouldn't that just be a waste of money?
What? Grounding the antenna? Not at all.
Old 05-28-2009, 05:37 PM   #10
FW
1/2" EMT is around 1/4 the price of #6 copper at $0.80/ft. Why not practical, obstructions?
Old 05-28-2009, 05:38 PM   #11
Res Ipsa Loquitur
What about soldering the ends of the conductors together at each end of the romex to add an electrical as well as mechanical bond to the 3 conductors?
"I think HD's price of 0.80/ft is robbery" Supply and demand- Economics 101 LOL!!
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 05-28-2009, 07:29 PM   #12
DIYer
Putting things in parallel can lead to things like cascade failures. Don't do it if you don't have to.
Gigs is offline   Reply With Quote
Old 05-28-2009, 08:00 PM   #13
Electrical Contractor
kbsparky's Avatar
IF such a scenario was acceptable, it would be so stated in the Code.
You only have to use a #10 copper wire for that mast ground, if you think that using a #6 costs too much.
Old 05-28-2009, 09:32 PM   #14
Ok.
Strip the sheath, strip the insulation and twist the wires together.
Old 05-28-2009, 09:33 PM   #15
Rewards Points: 894
My first thought is that EMT running down the side of the house would be un-aesthetic, but on second thought, maybe no worse than #6 THHN. If I painted it to match the house, it would mostly go unnoticed.
1/2" EMT is only $1.65 for 10ft at HD, but what about the fittings?
I would need one 90 elbow. I suppose a standard elbow is cheap, but what if I ever wanted to really use this conduit for power?
Would code allow me to run say 3 #12 THHN (hot, neutral, ground) through the conduit and still use it as the antenna ground?
And then if I were to use it for power, I would need to weatherproof it. Those fittings are more expensive.
Then, maybe I'm going a lot further than I need to go. I already have a wall inside the house where I have pulled several new branches over the past couple of years, so I shouldn't need any more.
Thanks for all your help on this. It should be worth all the trouble once it's up.
FW
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Shocking kitchen appliance PirateKatz Electrical 21 12-17-2008 09:06 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 08:41 AM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 06:37 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
