Romex Connection To Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 11:35 AM   #1
romex connection to receptacle
i am intalling a blower to circulate air from the first floor to the second floor of my house. the blower is a 120v, 180w, 3 amp blower. inline will be a line voltage thermostat and then a variable frequency drive for motor speed contrrol. the blower will be located in an unfinished attic the thermostat and vfd will be located in a wall in the first floor. i will be running 14/2 romex for the circuit. i have a 15 amp receptacle in the attic. i would like to simply add a male plug to the end of the romex and plug it into the receptacle for ease of future maintenance and ease of connection. my question is would i run into any code issues w/ this application of the plug and romex as i will end up w/ an inspector onsite for the electircal inspection. thanks. drew.
apshirm is offline   Reply With Quote
Old 09-15-2011, 11:41 AM   #2
Licensed electrician
Rewards Points: 1,238
Cord caps are not listed for use with type NM cables. NM cables are also required to be secured within 12" of a box.
Old 09-15-2011, 12:14 PM   #3
Master Electrician
Rewards Points: 3,746
deleted
brric is offline   Reply With Quote
Old 09-15-2011, 03:28 PM   #4
Electrical Contractor
kbsparky's Avatar
Just install a short cordset on your blower, and plug that into your outlet.
Problem solved.
-KB
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
Switched Outlet, Power into the switch then to switched receptacle ryanwake Electrical 1 01-23-2011 01:52 PM
Switched Receptacle Question MrBill_DIY Electrical 3 11-21-2010 11:07 PM
Replacing duplex receptacle with nighlight - wiring question Rabu Electrical 6 05-02-2010 08:51 PM
20A or 15A receptacle ejlog Electrical 3 02-21-2005 07:29 PM
