-   -   romex connection to receptacle (http://www.diychatroom.com/f18/romex-connection-receptacle-117301/)
apshirm 09-15-2011 10:35 AM
i am intalling a blower to circulate air from the first floor to the second floor of my house. the blower is a 120v, 180w, 3 amp blower. inline will be a line voltage thermostat and then a variable frequency drive for motor speed contrrol. the blower will be located in an unfinished attic the thermostat and vfd will be located in a wall in the first floor. i will be running 14/2 romex for the circuit. i have a 15 amp receptacle in the attic. i would like to simply add a male plug to the end of the romex and plug it into the receptacle for ease of future maintenance and ease of connection. my question is would i run into any code issues w/ this application of the plug and romex as i will end up w/ an inspector onsite for the electircal inspection. thanks. drew.
Jim Port 09-15-2011 10:41 AM
Cord caps are not listed for use with type NM cables. NM cables are also required to be secured within 12" of a box.
brric 09-15-2011 11:14 AM
deleted
kbsparky 09-15-2011 02:28 PM
Just install a short cordset on your blower, and plug that into your outlet.
Problem solved.
