Romex In Conduit Outdoors - Electrical - DIY Chatroom Home Improvement Forum
Old 11-27-2012, 02:11 AM   #1
Romex in Conduit Outdoors
I have been reading threads regarding romex in conduit and romex in wet/damp locations and how they are a no-no. I was going to install some outdoor GFI outlets and a couple of lights under a deck and was wondering why I could not use Romex NM in 3/4" sch 40 grey conduit.
If the romex got wet ot GFI's would they not trip and so prevent any danger??
Also I read over heating might occur, but if I used 14/2 Romex in 3/4" Sch 40conduit I doubt it would get to temperatures above 90 degrees celsius or as warm as romex that ran through onsulation or insulated areas.
What am I missing? Is it dangerous or just code being overkill? I am not a licensed electrician just a DIYer so any advice is greatly appreciated. Thanks.
starrapido is offline   Reply With Quote
Old 11-27-2012, 02:42 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,892
Romex (NM cable) is not rated for use in wet locations because the jacket, paper liner, and (arguably) conductor insulation isn't designed to be water resistant. It's not an issue of some sort of temporary problem that a GFCI would fix - the problem is that the cable degrades and can eventually fall apart if it stays moist. When a conduit is installed in a wet location, the inside of the conduit is also considered a wet location. This makes sense in practice, because conduits DO NOT keep water out. Sometimes they even accumulate condensation inside them. Basically, conduit provides only physical protection from damage, not protection from environmental conditions. So if you can't use NM cable in a certain location due to water, putting it in conduit doesn't help. Note that there is usually no reason you can't run NM in conduit - but it's hard to do and only provides protection from damage.
UF cable is made specifically for this kind of situation. Use it instead.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
Old 11-27-2012, 07:33 AM   #3
Rewards Points: 1,562
Or use THWN individual wiring in conduit.
bob22 is offline   Reply With Quote
Old 11-27-2012, 11:00 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
My vote is for UF.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Does the romex need to be in Electrical Conduit naty0629 Electrical 3 05-01-2012 03:18 PM
Can I mix conduit and romex ACR_SCOUT Electrical 33 02-07-2012 11:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 06:57 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
