Romex/conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 02:30 PM   #16
Just call me Andrew
Rewards Points: 1,020
You wouldn't need to attach a board to your walls. You just screw it into the bottom of the joists, just as you would a wire, and run the wire along side the board.
As far as specifics on the board, not sure, but a 1x2 would probably work.
Andrew
secutanudu is offline   Reply With Quote
Old 09-12-2010, 02:55 PM   #17
Actually it reads that the running board is attached across the joists
Then the wire is attached TO the running board
This is the way I have the wires running in my equipment room
Instead of tucking them back against the sill plate
If you go with conduit you then need to take into account derating
Old 09-12-2010, 02:57 PM   #18
Just call me Andrew
Can you just zip-tie it? Seems pretty easy.
Andrew
Old 09-13-2010, 07:59 AM   #19
Rewards Points: 79
Cynthia, I've read this ongoing account and admit that I am NOT qualified to offer advice BUT - Conduit is pretty cheap - can you run two?
And Jimmy - You've got inspectors that actually go into crawl spaces?
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-13-2010, 12:16 PM   #20
liscenced electrician
Rewards Points: 538
thats probably the reason its never come up with an inspector. On my personal house, half the house has a basement, half has a crawl space. At the time of my rough in inspection, my cinder block walls only went as high as the dirt for the crawl space. So you could see directly into the crawl space from where the electrical panel is mounted. Since then ive built 2x4 walls in front of the cinder blocks to finish the basement
jimmy21 is offline   Reply With Quote
Old 09-13-2010, 01:37 PM   #21
the Musigician
DangerMouse's Avatar
My inspector says zip ties are fine, and never mentioned anything about my stapling in the crawl space. I'll be having my rough-in in the next day or two so I'll ask then. He liked how I ran the wires up above on slats, then I black cloth-taped every 12" and staple-gunned the tape closed so it'll never unravel. He did say zip ties would have been fine too. Po)
DM
