Romex In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 05:51 AM   #1
Rewards Points: 150
Romex in conduit
Hey all, I'm wiring my garage with 12/2 romex and i want to run the cable through the ceiling joist and drop down to each receptical mounted to the concrete block wall with romex in conduit. What size conduit can I use for 2 cables of 12/2 (down then back up to next drop) Thanks
James Con is offline   Reply With Quote
Old 02-20-2009, 07:17 AM   #2
What type garage is this, attached or detached?
rgsgww is offline   Reply With Quote
Old 02-20-2009, 07:35 AM   #3
Rewards Points: 150
Attached
Old 02-20-2009, 08:26 AM   #4
Since you are sleeving it through the conduit, fill does not apply. You can use 1/2" if you like. Not sure how easy its going to be. Staple the romex before entering the conduit, make sure the ends of the conduit are smooth, use bushings or, if your using 1/2" emt, you can find an emt to romex fitting at the big box stores.
Before entering the box, you may want to use an offset, since the conduit runs flush to the wall. Use the appropirate clamps to secure the conduit to the masonry.
is it OK to have 12-2 romex in 1/2" outdoor conduit red86yota Electrical 23 01-16-2009 08:16 PM
Romex in conduit? tommy potatoes Electrical 14 01-13-2009 08:28 PM
Why not Romex in Conduit? Mr Chips Electrical 3 11-08-2008 09:58 AM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
