Romex In Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 11:20 PM   #1
Romex in Conduit
So I think I messed up and installed 4 new Romex 20a circuits to a new kitchen.
I popped a hole int he side of the house (raised foundation) and attached a w/p box to the wall and connected it to the electrical box.
I thought it was ok to run the romex through conduit but its on the outside of the house, so I guess that is a wet location. So then how do I transition from romex to wires to the electrical panel?
This house also has no grounded outlets. Without running new wire how can I ground the outlets? All of them?
Thanks!
Bryan
bsoth is offline   Reply With Quote
Old 04-07-2012, 11:25 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You would need to splice the romex to individual conductors rated for wet locations. The most common type is THHN/THWN. This wire is dual rated.
Old 04-07-2012, 11:37 PM   #3
Thanks for the info. Is there a minimum distance the box should be off the ground? I am about 6" above the cement.
Just wire nut the THHN to the Romex wire?? I shoulda put the jbox under the house then and run a conduit out and up...
Old 04-07-2012, 11:42 PM   #4
k_buz's Avatar
no
and
yes
Old 04-07-2012, 11:43 PM   #5
Rewards Points: 6,652
If the area does not flood, and you are not worried about anyone using it to place their foot while standing there, that is fine. As for wirenutting, you can do that, or use Wago's.
Can I mix conduit and romex ACR_SCOUT Electrical 33 02-07-2012 11:46 AM
loose Romex entering EMT conduit inside ceiling amakarevic Electrical 6 11-02-2011 10:32 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 06:57 PM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 06:01 PM
