Romex Cable And Fibreglass Insulation - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 10:46 AM   #1
Romex Cable and fibreglass insulation
Here is a question:
I have outside walls with fibreglass insulation (owen corning pinkplus) with a paper vapor retarder cover. This cover is not fire resitant unless covered by drywall or similar (big warning on the paper). So far no problem.
Now I need to run cables in the same wall. The question now is: Can Romex be run on top of the paper (and in contact of the paper) or does it have to be buried inside the fibre glass?
Alertanive would be to remove the paper around teh area where cables are run.
fmva is offline   Reply With Quote
Old 11-13-2008, 10:50 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
I try to run the cables in the middle of the fiberglass, but either is fine.
Old 11-13-2008, 10:59 AM   #3
RippySkippy's Avatar
What jbfan says...when you hang it...split it so you have 1/2 on the back side, 1/2 on the front, you'll be fine.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-13-2008, 11:03 AM   #4
Rewards Points: 126
In the insulation, out of the insulation anyway you can get it from point A to point B. If you are fishing it into existing walls, no staples required. If you are running cables in new construction (open walls) then you must secure the cables with approved staples.
Reference NEC article 334.
Old 11-13-2008, 12:34 PM   #5
Thanks!
Question answered... I'll put the cable between the insulation.
Thanks!
Tags
insulation , romex
