Romex In Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 07:32 PM   #1
Rewards Points: 160
romex in attic
I need to add two home runs for an addition I've built on my house. Easiest would be through the attic but there's two feet of blown in insulation, so running the romex across the ceiling joists will be really nasty. Can I run it in one of the side angles of the w-trusses just below the roof peak? Seems like it's out of the way there. Thanks. -- Phil S
philS is offline   Reply With Quote
Old 01-13-2009, 07:54 PM   #2
sounds OK. hate hidden wires.
II Weeks is offline   Reply With Quote
Old 01-13-2009, 08:03 PM   #3
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Do you prefer your wire exposed?
Hiding wires, Hiding junctions
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-13-2009, 08:06 PM   #4
Rewards Points: 160
forgot to mention, there's no staircase or pull-down ladder access to attic. Found an earlier thread here that sounds like i'm ok since there'll be a full 3.5" separating romex from roof.
Old 01-13-2009, 09:18 PM   #5
Please don't splice in the attic...it makes the next person's job much harder.
rgsgww is offline   Reply With Quote
Old 01-13-2009, 09:23 PM   #6
Electrician
It makes no difference...
chris75 is offline   Reply With Quote
Old 01-13-2009, 09:30 PM   #7
Rewards Points: 160
Thnks guys. This job just got quite a bit more pleasant!
Old 01-14-2009, 04:43 PM   #8
It makes a HUGE diffence. Here, you can't really walk in the attics. They are strictly for insulation and mechanical systems. It's hard enough troubleshooting when you can see all the jb's. When they are buried in the attic and it's 160 degrees up there....not good.
220/221 is offline   Reply With Quote
Old 01-14-2009, 06:11 PM   #9
Over here most houses have 1-2 ft of blown in insulation, in the attic, temps in summer may get up to 160 degrees, in winter, it will get below 0.
Old 01-14-2009, 06:50 PM   #10
Rewards Points: 257
If a splice if properly made, how likely is it that someone will have to come back and trouble shoot it? I hate working in attics, but if it was unavoidable, I'd put a splice there before I'd leave a blank plate one of the rooms below.
LanterDan is online now   Reply With Quote
Old 01-14-2009, 10:25 PM   #11
Electrician
You guys done crying?
Old 01-14-2009, 10:30 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Whats the matter? Can't feel sorry for the next guy?
I'm not concerned how the next guys feels, as long as it is to code.
Old 01-14-2009, 10:31 PM   #13
Electrician
The way I feel is, if it were easy somebody else would be doing it, plain and simple.
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Romex laying across joist in attic? Doug Crf Electrical 4 08-17-2006 05:53 PM
Running Romex up from basement to attic tra999 Electrical 1 07-25-2006 05:21 AM
Running Romex in the attic mdalli Electrical 7 07-06-2006 06:35 PM
