Romex 6/2 NM-B Wire And Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 09:49 PM   #16
Electrician
Rewards Points: 150
Rjniles is right about how cheap aluminum(AL) is. And AngelArs is right to follow the instructions. Personally, I couldn't find the copper restriction in either instruction manual. However, AL would be a whole lot of extra work. You'd have to research the listing(label) on the terminations and the equipment to see if it's allowed and for torque specs. You'd have to use listed for AL wire connectors (not wire nuts). And use Noalox and a torque screwdriver. If that's fun for you let me know.
Glennsparky is offline   Reply With Quote
Old 10-20-2012, 11:52 AM   #17
Insatiable Learner
Rewards Points: 166
Smile
Regarding the fire seal, I've seen several videos showing that the caulk burns very easily. Since it can ignite so easily, what is the point of buying and using it?
AngelArs is offline   Reply With Quote
Old 10-20-2012, 02:54 PM   #18
Oso954's Avatar
Rewards Points: 1,116
Are you saying that you have seen videos showing the 3M fire sealant FB136 burning easily ?
Fire sealant is not a caulk, except in a very generic usage of the word.
Oso954 is offline   Reply With Quote
Old 10-20-2012, 02:59 PM   #19
Insatiable Learner
Rewards Points: 166
Question
Not just the 3M brand but other brands as well. In fact there is only one brand that I've seen that does not catch on fire. How can these other brands be a fire seal if they easily catch on fire?
Old 10-20-2012, 09:21 PM   #20
joed's Avatar
Rewards Points: 12,890
Was the caulk dry or fresh out of the tube when it was burning?
Old 10-20-2012, 09:56 PM   #21
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
True fire caulk will expand due to fire. Maybe that is what you saw and interpreted it as being on fire.
Old 10-20-2012, 10:19 PM   #22
Insatiable Learner
Rewards Points: 166
Smile
It was fully cured
Nope. There are many examples on line but here are two quick ones. I guess a picture (or video in this case) is worth a thousand words.
Example One
Example Two
Old 10-20-2012, 10:23 PM   #23
k_buz's Avatar
That is firestop expanding foam, not fire caulk. I don't know anything about the foams, never used them.
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
Can I mix conduit and romex ACR_SCOUT Electrical 33 02-07-2012 10:46 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 11:41 AM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
