Romex 6/2 NM-B Wire And Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 01:33 PM   #1
Insatiable Learner
Rewards Points: 166
Question
Romex 6/2 NM-B Wire and Conduit
I need to run some Romex® 6/2 NM-B wire (around 40 feet) from my garage to my basement. One of the walls it's going through is masonry. Does code require I use conduit? If not, is there any harm in running it through conduit? Thanks
AngelArs is offline   Reply With Quote
Old 10-19-2012, 02:50 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Conduit not required but you can sleeve it thru the masonry.
What will you use the 6/2 for?
Coastal South Carolina
Old 10-19-2012, 02:56 PM   #3
Insatiable Learner
Rewards Points: 166
Smile
I am in the process of planning a generator/transfer box install. I know that 6/2 is overkill but one day I may want to upgrade to a bigger generator and don't want to have to rewire. I want to do the wiring once and do it right
Old 10-19-2012, 03:12 PM   #4
A "Handy Husband"
rjniles's Avatar
Unless you are planning on a 120 volt generator with not plans to ever upgrade to 240, I would run 6/3
Old 10-19-2012, 03:14 PM   #5
Electrician
Rewards Points: 150
You're going to need 6-3 with ground. 6-2 is for 120V generators. 6-3 is for 240V ones. Are you using a transfer switch? Or an interlock kit?
Glennsparky is offline   Reply With Quote
Old 10-19-2012, 03:32 PM   #6
Insatiable Learner
Rewards Points: 166
Smile
I'm sorry, after reviewing you are correct, I'll be running 6/3. Thanks for catching that before I ordered the wire. The inlet box will be a Reliance PR50. Pretty sure the transfer box will be the Reliance Q510C because a Generac transfer box would require a subpanel. So far the generator will be the Generac XG7000E.
Old 10-19-2012, 03:34 PM   #7
joed's Avatar
Rewards Points: 12,016
Garage to basement will need to fire block sealed.
Old 10-19-2012, 03:39 PM   #8
Insatiable Learner
Rewards Points: 166
Smile
Really? Didn't need to do this when I ran the wire for my compressor. What is the best way to fire block seal?
Old 10-19-2012, 03:44 PM   #9
A "Handy Husband"
rjniles's Avatar
Fire block caulk
http://www.grainger.com/Grainger/3M-...121019194309:s
Lots of other brands also.
Any building supply, electrical supply or home center carries it
Old 10-19-2012, 03:49 PM   #10
Insatiable Learner
Rewards Points: 166
Smile
OK THANKS!
I was planning on caulking anyway so I'll just use that kind. I will be using Fire Block insulation also.
Old 10-19-2012, 04:10 PM   #11
A "Handy Husband"
rjniles's Avatar
You might want to look at Aluminum SER 4-4-4-6 cable. Will be cheaper than 6/3 NM copper
Old 10-19-2012, 05:12 PM   #12
Insatiable Learner
Rewards Points: 166
Smile
Reliance PR50 instructions specifically state to use only solid copper wire.
Old 10-19-2012, 06:29 PM   #13
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
6-3 Romex will not come in solid.
Old 10-19-2012, 06:54 PM   #14
Insatiable Learner
Rewards Points: 166
Smile
Solid as in solid bare copper strands.
Old 10-19-2012, 07:03 PM   #15
Semi-Pro Electro-Geek
Rewards Points: 2,902
That's not what "solid" means with respect to wire. "Solid" means one single cylinder of metal per conductor. More than one is "stranded". #6 solid copper does exist (even #4 solid exists), but it's really unpleasant to work with, and you won't find cable that size with solid conductors.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 03:41 AM
Can I mix conduit and romex ACR_SCOUT Electrical 33 02-07-2012 11:46 AM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 12:41 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
