Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 08:04 PM   #1
romex
I am replacing old flush mount ceiling light fixtures and all the lights in the home centers have warnings to use only nmb 90 deg. c. All my wireing is nm. Where can I find fixtures that can use nm 60 deg. c. HELP
bearpaw is offline   Reply With Quote
Old 09-06-2013, 07:03 AM   #2
Rewards Points: 788
how old is your nm cable, most nm cable is rated 90C, if you really need fixture that doesn't heat, go with led light fixtures, they don't have any temp requirements
carmusic is offline   Reply With Quote
The Following User Says Thank You to carmusic For This Useful Post:
bearpaw (09-06-2013)
Old 09-06-2013, 09:40 AM   #3
joed's Avatar
Rewards Points: 13,752
If the cable is before 1985 then it is probably NM which is 60C rated. If the cable is marked NM-B then it is 90C cable.
The only fixture that have the 60 rating will be ones that hang down. Anything that hugs the ceiling will be the higher rating.
The Following User Says Thank You to joed For This Useful Post:
Romex in Conduit Outdoors starrapido Electrical 3 11-27-2012 10:00 AM
Romex on basement wall to panel iceclimber2001 Electrical 3 08-13-2012 07:40 AM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
