Old 03-13-2013, 07:18 PM   #1
Romex
Is it ok to run 2-12/2 romex cables in a 3/4 pvc conduit? Will there be a heat problem?
fitter457 is offline   Reply With Quote
Old 03-13-2013, 07:21 PM   #2
Romex
Not supposed to run romex in conduit. Except a short run too protect the romex on a cement wall.
Someone will be along to give the NEC code on it and a more technical reason why not!
Hardway is offline   Reply With Quote
Old 03-13-2013, 07:24 PM   #3
Romex
What is the reason why your not suppose to? Are there any dangers?
Old 03-13-2013, 07:40 PM   #4
Electrical Contractor
Romex
The romex can not be installed in a damp or wet location, so if the conduit is inside you are fine.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Kyle_in_rure (03-13-2013)
Old 03-13-2013, 07:50 PM   #5
Romex
It will be inside a building that makes cheese. It will be humid. Think it will be ok.
Old 03-13-2013, 07:51 PM   #6
Electrical Enthusiast
Romex
How long of a run are we talking about? I believe if there are so many wires in a conduit you have to do some derating because of heat. Hopefully someone will come along with specifics.
Kyle_in_rure is offline   Reply With Quote
Old 03-13-2013, 07:53 PM   #7
E2 Electrician
stickboy1375's Avatar
Romex
its fine, the only issue that arises is conduit fill.
Old 03-13-2013, 07:54 PM   #8
Romex
If it is a long pull, I might step up to 1" just to make it easier.
Old 03-13-2013, 07:57 PM   #9
E2 Electrician
Romex
Or just use a different wiring method since I spent the time to install the conduit to begin with... :-\
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (03-13-2013)
Old 03-13-2013, 08:33 PM   #10
Romex
Thanks for the info guys
Old 03-13-2013, 09:08 PM   #11
Licensed Electrician
k_buz's Avatar
Romex
Depending on the buildings classification NM may not be legal in conduit or otherwise.
Location...Location...Location
Old 03-13-2013, 09:13 PM   #12
E2 Electrician
Romex
Since this is a DIY site, I hope that it is Residential, and a non issue...
Old 03-13-2013, 09:55 PM   #13
k_buz's Avatar
Romex
Just covering the bases.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (03-13-2013)
Old 03-13-2013, 09:57 PM   #14
E2 Electrician
Romex
totally missed that post... Thanks.
Old 03-13-2013, 10:11 PM   #15
Romex
Does the NEC have special rules for cheese-making buildings?
Romex in Conduit Outdoors starrapido Electrical 3 11-27-2012 11:00 AM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
