Romex
Is it ok to run 2-12/2 romex cables in a 3/4 pvc conduit? Will there be a heat problem?
Someone will be along to give the NEC code on it and a more technical reason why not! |
What is the reason why your not suppose to? Are there any dangers?
The romex can not be installed in a damp or wet location, so if the conduit is inside you are fine.
It will be inside a building that makes cheese. It will be humid. Think it will be ok.
How long of a run are we talking about? I believe if there are so many wires in a conduit you have to do some derating because of heat. Hopefully someone will come along with specifics.
its fine, the only issue that arises is conduit fill.
If it is a long pull, I might step up to 1" just to make it easier.
Thanks for the info guys:thumbsup:
Depending on the buildings classification NM may not be legal in conduit or otherwise.
Does the NEC have special rules for cheese-making buildings?:jester:
| All times are GMT -4. The time now is 08:57 AM. |
