Romex 12/3 Or 12/4 - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 06:52 PM   #1
Question
Romex 12/3 or 12/4
If you are running a length of Romex 12/3 the black and red of which are the Hs from two different CBs, can you use the same white wire for the N for both circuits?
Basically can you use 12/3 for two CBs using the same white wire for the N for both circuits?
highdeserthome is offline   Reply With Quote
Old 01-10-2012, 06:53 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Yes. This is known as a multiwire branch circuit.
Old 01-10-2012, 06:59 PM   #3
Love for Construction
<*(((><'s Avatar
Yes, its called a Multi-wire Branch Circuit (MWBC). It has been covered on this site quite a bit.
1. The two circuits have to be on opposite phases of each other so the power on the neutral will not be cumulative.
2. The circuit breakers (depending on location, but always recommended) need to have a handle tie, so that one cannot be shut off independently from the other circuit.
3. The neutral wires at the receptacles must be pig-tailed before attaching to the receptacle.
-luke-
<*(((>< is offline   Reply With Quote
Old 01-10-2012, 07:07 PM   #4
Question
If I put the two leads of my multimeter on the hots, if it reads 240 then they are opposite phases? Usually for CB immediate next to each other or odd and even location will be opposite phase? Is this true even for the Pushmatic Bulldog?
Old 01-10-2012, 07:10 PM   #5
"The two circuits have to be on opposite phases of each other so the power on the neutral will not be cumulative."
Thanks This info really answered my question. I wondered about the load on the N for this setup.
Old 01-10-2012, 07:11 PM   #6
MarginallyQualified
Rewards Points: 2,464
If the wire isn't already installed... try to avoid putting a MWBC in.
If it is installed... be careful of how the rest is done.
Old 01-10-2012, 09:04 PM   #7
kbsparky's Avatar
Bulldog breakers are a different animal. Be sure to use a double-pole breaker, where both sides are connected with a top piece.
And yes, when you have properly connected it up, you will measure 240 Volts between the black and red conductors.
-KB
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 01:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 01:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 07:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 02:53 PM
12/3 Romex to Feed 2 Circuits? DaveHembree Electrical 22 09-28-2007 09:24 AM
