ROHS Compliance Replace Ballast Help - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 10:16 AM   #1
Rewards Points: 49
ROHS compliance replace ballast help
Hi,
I will post pictures to help my explanation.
1) Im replacing two 2tube 32wT12 ballasts with ONE 4tube 32wT8 ballast.
If this sounds unwise let me know.-)
2) Keystone made the old broken ballast, and they said make sure the new ballast is properly GROUNDED. Is this simply a copper wire from the fixture metal part to the box? (all EMT conduit here in IL).
Thanks!
ROHS compliance replace ballast help-img_6003.jpg   ROHS compliance replace ballast help-img_6006.jpg
kree is offline   Reply With Quote
Old 01-30-2014, 10:50 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You need to be sure the emt is fastened with the proper connecter to the metal fixture where the power supply enters. At that point the screws that hold the ballast to the fixture will ground it to the metal and via the metal to the emt.
Grounding is important in your case mainly for protection against electrocution in the event of a ground fault which would energize the fixture metal if not properly bonded to the emt.
The metal of the fixture when proper grounded to the ballast also aids in starting the lamps but this would be more important if you were using an electromagnetic ballast or installing in a cold location like a walk in freezer.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-30-2014, 11:35 AM   #3
Rewards Points: 49
Thanks!
Yes there is at least one screw that goes through the metal part of the fixture directly through one mounting hole in the box.
Will that do?
Old 01-30-2014, 12:03 PM   #4
Licensed electrician
Rewards Points: 1,780
If there is a box above the fixture it needs to be fully accessible.
Old 01-31-2014, 08:37 PM   #5
Rewards Points: 266
Let's be sure that the sockets are right for the new ballast, shunted or unshunted.
ionized is offline   Reply With Quote
Old 02-17-2014, 12:42 PM   #6
Rewards Points: 49
Thanks. Shunted, not shunted....Im not familiar with those terms.
Anyway...replaced T12two two-light ballasts with a new T8 four-light ballast.
$20....and about 8 wirenuts/connections. It works!
The fixture is 7 years old, and always had electrical ballasts...once I found out they made a four-light ballast that I could use it halved my cost.
Thanks again
The Following User Says Thank You to kree For This Useful Post:
Stubbie (02-17-2014)
Old 02-17-2014, 01:50 PM   #7
Rewards Points: 266
Shunted sockets are for instant start and there is only one part of the circuit connected into each socket. The only current that flows is through the arc between the two filaments in the lamp. There maybe two wires connected to some sockets for ease of connecting things.
Unshunted sockets are for rapid start/programmed start. They have two circuits connected to each socket. One circuit is providing current through the filament, from one socket connection to the other, to control its temperature. The other circuit provides the arc current just as in the instant start.
Bad ballast from store? Wrong ballast? Hossenfeffer Electrical 6 05-24-2013 11:42 PM
Breaker buzz when ballast is on?!?! Help please lafcam Electrical 4 04-22-2013 07:00 PM
T8 Electronic Ballast Wiring - Help Needed!! mikeeyuk Electrical 1 02-17-2013 06:41 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
DIY Replace Ballast? roztom Electrical 6 12-12-2009 09:09 AM
