Rocker-style Timer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 05:53 PM   #1
Just call me Andrew
Rewards Points: 1,020
Rocker-style timer switch
I am looking for a switch that will turn my bath fan on for a specified amount of time then shut off.
I already am aware of these two types of modern (non spring) timers:
Leviton makes a switch that looks like a standard rocker switch. It has a preset "Off in XXX hours behind the cover plate." I want this exactly, but one that gives you smaller increments, maybe 10-minute instead of hour-long increments up to 14 hours. Anyone know of one?
This is the Leviton switch:
http://www.leviton.com/OA_HTML/ibeCC...minisite=10022
I don't need this switch to also control lights, I'll do that with a separate switch.
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 02-24-2010, 06:34 PM   #2
You might want to check out the RT1 timer from Pass & Seymour.
http://legrand.us/PassAndSeymour/Lig...imer/RT1W.aspx
It has preset buttons for 1, 5, 10, 20, 30 and 60 minutes.
brich is offline   Reply With Quote
Old 02-25-2010, 06:43 AM   #3
Just call me Andrew
Not exactly what I'm looking for...but that Pass & Seymour is much nicer than the other one. I'll go with that if I can;t find a rocker one. Thanks!
Andrew
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
Replacing a wall outlet dimmer switch with a rocker switch Lonepine Electrical 1 01-05-2010 10:18 AM
Replacing Toggle Switch with Rocker Switch dogsitter Electrical 8 07-04-2009 05:24 PM
How to install leviton 6230 timer switch diydan Electrical 12 05-27-2009 09:52 PM
Installing timer switch, no ground wire in switch box diydan Electrical 2 05-25-2009 07:51 PM
