Old 12-29-2011, 08:01 PM   #1
Ring/Ringless Interchangeability
I have a 100 AMP load center with a ring. The power company rep says that they only use ringless meters. Am I toast or are they pretty much interchangeable? Is there a way the power company can install one of their ringless meters into my load center box which has a ring?
jackwashere is offline   Reply With Quote
Old 12-29-2011, 09:06 PM   #2
joed's Avatar
Sounds like a current transformer. Can you post a picture. I have never seen a CT in residential. The meter goes in a meter base, not the load center. Sounds like you are attempting to use an industrial panel in your home.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-29-2011, 10:37 PM   #3
It's not a load center. It's a meter box. My apologies. It has a ring. Edison told me they have ringless meters.
Old 12-29-2011, 11:23 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
They are not interchangeable.
A ring type meter has you install the meter socket cover .. then plug in the meter .. at that point you install a metal ring that engages the rim of the meter and a rim on the cover. Then a sealing lock is placed on the ring.
A ringless meter has you plug in the meter then install the cover. The cover holds the meter in place. This allows you to remove the cover without removing the meter if any testing or servicing is required. Then a sealing lock is placed on a protruding tab at the bottom of the cover.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
plummen (12-30-2011)
Old 12-30-2011, 04:34 AM   #5
The meters will fit in either meter socket.They are putting digital meters in the old 60 amp style around here.
bobelectric is offline   Reply With Quote
Old 12-30-2011, 01:02 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
How do they get a ring on a ringless cover ? The ringless cover has no 'rim' for a ring to attach .. do they just not install a ring ? I realize the meters will fit but I'm not understanding how the meter has been changed to allow it to be secured in the two different meter sockets because the covers are different. They are doing the digitals around here also .. only to all service sizes. The utility employees either have a ring less meter or ringed meter on the truck.
Stubbie
Old 12-30-2011, 09:05 PM   #7
Electrical Contractor
kbsparky's Avatar
The meter has not changed. It has always had the outer "ring" and fits into either a ring-type socket, or the ringless ones.
As stated elsewhere in this thread, the ringless covers allow one to remove the cover without removing the meter for testing, etc.
-KB
Old 12-30-2011, 10:20 PM   #8
Licensed electrician
Aren't the ringless ones single? The ones with rings are married right?
Old 12-30-2011, 10:29 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
It appears I don't have a clue ....
Stubbie
Old 12-30-2011, 10:30 PM   #10
I think someone has started New Years Eve partying very early!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-30-2011, 10:38 PM   #11
Not a drop.
Best of the seasons to all.
Smoke detector interchangeability rjniles Electrical 3 09-26-2007 06:53 PM
