#1 |
Ring Circuit Tripping
I've just moved into a house, and my three plug in radiators (separate rooms) are tripping a fuse in the consumer unit.
One works fine on it's own. The problem occurs when I have two or three on together and they heat up. Although the house is 25 years old, it was previously a rental, so had to pass the necessary regulatory tests. The switch fuses in the consumer unit look reasonably new as well. Before I call in a sparks, is there anything I can do here? p.s. In Australia |
#2 |
this sounds like a simple case of overload. Too many amps on one circuit.
turn off that circuit and draw yourself a map of what recepticles are no longer working. do this for each circuit in your panel. (cu) plug the heaters into different circuits.
Master Electrician |
#3 |
how many watts are the heaters? What size fuse is on the circuit? Sounds like an overload to me. To many things on one circuit.
#4 |
Thanks guys. Yes I think it's clearly an overload, becasue I tried them on another circuit at the weekend. This time I got two to work together, but the third tripped the fuse.
Particulars:- Heaters = 2400 Watts each House Voltage = 230V Fuse = 16A Not sure of the fuse capacity in my last house - but I didn't have this problem there. So could I not try replacing the 16A fuse with say, a 20A? |
#5 |
I am not sure where you live so I do not know the code on wire size, but DO NOT replace the fuse without making sure that the wire is rated for that fuse size.
since these draw 10.5 amps each I am supprised that you get two to run without tripping a breaker. I would reccomend running the necessary extra circuits where needed to make this a safe installation.
| Display Modes | |
| Wiring in New Addition? | sandyman720 | Electrical | 6 | 11-27-2011 04:34 PM |
| Loose electrical outlets | travishume | Electrical | 30 | 08-01-2008 08:21 PM |
| a/c unit tripping circuit breaker | StrandedJoe | HVAC | 12 | 07-13-2007 11:05 AM |
| So lost - electrical requirements please help | lapsis9 | HVAC | 4 | 12-20-2006 09:09 PM |
| Adding new circuit breakers to 100 amp sub panel | DrP | Electrical | 8 | 05-25-2006 11:05 PM |
