-   -   Ring Circuit Tripping (http://www.diychatroom.com/f18/ring-circuit-tripping-8682/)
Loftus 05-25-2007 12:31 AM
I've just moved into a house, and my three plug in radiators (separate rooms) are tripping a fuse in the consumer unit.
One works fine on it's own. The problem occurs when I have two or three on together and they heat up.
Although the house is 25 years old, it was previously a rental, so had to pass the necessary regulatory tests. The switch fuses in the consumer unit look reasonably new as well.
Before I call in a sparks, is there anything I can do here?
p.s. In Australia
jwhite 05-25-2007 06:08 AM
this sounds like a simple case of overload. Too many amps on one circuit.
turn off that circuit and draw yourself a map of what recepticles are no longer working. do this for each circuit in your panel. (cu) plug the heaters into different circuits.
joed 05-25-2007 03:40 PM
how many watts are the heaters? What size fuse is on the circuit? Sounds like an overload to me. To many things on one circuit.
Loftus 05-27-2007 07:56 PM
Thanks guys. Yes I think it's clearly an overload, becasue I tried them on another circuit at the weekend. This time I got two to work together, but the third tripped the fuse.
Particulars:-
Heaters = 2400 Watts each
House Voltage = 230V
Fuse = 16A
Not sure of the fuse capacity in my last house - but I didn't have this problem there.
So could I not try replacing the 16A fuse with say, a 20A?
jwhite 05-28-2007 03:58 PM
I am not sure where you live so I do not know the code on wire size, but DO NOT replace the fuse without making sure that the wire is rated for that fuse size.
since these draw 10.5 amps each I am supprised that you get two to run without tripping a breaker.
I would reccomend running the necessary extra circuits where needed to make this a safe installation.
