Rim Around Lighting Fixture Fell Off. HELP - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2012, 06:18 PM   #1
Question
Rim around lighting fixture fell off. HELP
I have recessed lighting in my ceiling. There is a plastic rim thing around each bulb (It's technical name is a "trim ring") somehow attaches to a thin metal part of the lighting fixture (the baffel?). The rim fell off, and I am unsure of how to re-attach it. I have tried many methods, but none have worked out. An image of a similar fixture can be found at the link below:
[URL="http://http://bscconstruction.files.wordpress.com/2010/03/12-23-09-lighting-ceiling-fans-015.jpg"]
Any help would be appreciated.
rbrtadlsn is offline   Reply With Quote
Old 05-23-2012, 06:46 PM   #2
bbo
[url="http://http://bscconstruction.files.wordpress.com/2010/03/12-23-09-lighting-ceiling-fans-015.jpg"]
there should be some springs that attach to the both the housing and the "trim ring" the springs allow you to attach both ( with no bulb screwed in)
be sure the power is shut off to the fixture before attempting work on it. From the circuit breaker.
bbo is offline   Reply With Quote
Old 05-23-2012, 07:07 PM   #3
Rewards Points: 12,794
If it fell off then it may be the wrong trim ring. There's two differant types.
One with two springs and one with two wires that pull it tight to the ceiling.
Lighting fixture may not be supported by nonmetallic conduit whatrymes Electrical 5 03-09-2011 06:36 PM
DIY Lighting Fixture stubits Electrical 11 10-13-2009 02:20 PM
Help with a lighting fixture llVeXXll Electrical 2 09-16-2009 10:29 PM
Adding recessed lighting where old fixture was ConstantChange Electrical 4 01-15-2009 05:42 PM
Installing Lighting Fixture lilsara88 Electrical 3 01-03-2009 09:49 PM
