Rigid EMT From Under Floor Or Through Drywall - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 12:57 PM   #1
Rigid EMT from under floor or through drywall
Hello,
Long time reader, first time poster.
I am currently in the process of a remodel and am wondering if anyone here has any experience with this.
Ideally I am looking for a clean transition from NM which will be run under the sub floor in a few locations and also run above drywall in a few others to transition to Rigid EMT. This would be for the purpose of overhead lights and switch legs and also for wall mounted receptacles.
I know for the ceiling I could easily use an extension ring and branch off of that however I was hoping for something cleaner. The wall mount receptacles are to be mounted on brick.
Any suggestions?
onetwoclicks is offline   Reply With Quote
Old 05-23-2013, 01:15 PM   #2
JW
mm11's Avatar
Rewards Points: 622
Set a junction box.
I'm not aware of any listed products to change-over from romex to EMT.
mm11 is offline   Reply With Quote
Old 05-23-2013, 01:43 PM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
http://www.rakuten.com/prod/1-2in-nm...ngId=147088627
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-23-2013, 01:47 PM   #4
Licensed electrician
Rewards Points: 1,874
Because you cannot strip the outer sheath off the the NM, the EMT is only a sleeve. Slide one of these on each end of the EMT.
http://www.aifittings.com/catalog/em...ting-bushings/
Old 05-23-2013, 02:00 PM   #5
Thanks for the replies so far!
Not to come off as dense but if I understand this properly it's suggested I use a coupling such as what Philly Master linked to and to use the insulating bushings Jim Port linked to bring me to next box where I could switch from NM to THHN?
Old 05-23-2013, 02:12 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
Just a thought...any reason for not using PVC? It won't rust.
Old 05-23-2013, 02:47 PM   #7
ddawg16- For aesthetic reasons I'd like to keep with rigid emt, it will work well with the exposed brick in the space.
Old 05-23-2013, 03:09 PM   #8
You could use a slip on bushing at the far end of the sleeve and use an EMYT connector at the box end. Make your transition in the box.
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 06:07 AM
