-   -   Rigid EMT from under floor or through drywall (http://www.diychatroom.com/f18/rigid-emt-under-floor-through-drywall-180338/)
onetwoclicks 05-23-2013 12:57 PM
Hello,
Long time reader, first time poster.
I am currently in the process of a remodel and am wondering if anyone here has any experience with this.
Ideally I am looking for a clean transition from NM which will be run under the sub floor in a few locations and also run above drywall in a few others to transition to Rigid EMT. This would be for the purpose of overhead lights and switch legs and also for wall mounted receptacles.
I know for the ceiling I could easily use an extension ring and branch off of that however I was hoping for something cleaner. The wall mount receptacles are to be mounted on brick.
Any suggestions?
mm11 05-23-2013 01:15 PM
Set a junction box.
I'm not aware of any listed products to change-over from romex to EMT.
Philly Master 05-23-2013 01:43 PM
http://www.rakuten.com/prod/1-2in-nm...ngId=147088627
Jim Port 05-23-2013 01:47 PM
Because you cannot strip the outer sheath off the the NM, the EMT is only a sleeve. Slide one of these on each end of the EMT.
http://www.aifittings.com/catalog/em...ting-bushings/
onetwoclicks 05-23-2013 02:00 PM
Thanks for the replies so far!
Not to come off as dense but if I understand this properly it's suggested I use a coupling such as what Philly Master linked to and to use the insulating bushings Jim Port linked to bring me to next box where I could switch from NM to THHN?
ddawg16 05-23-2013 02:12 PM
Just a thought...any reason for not using PVC? It won't rust.
onetwoclicks 05-23-2013 02:47 PM
ddawg16- For aesthetic reasons I'd like to keep with rigid emt, it will work well with the exposed brick in the space.
Jim Port 05-23-2013 03:09 PM
You could use a slip on bushing at the far end of the sleeve and use an EMYT connector at the box end. Make your transition in the box.
