Old 08-20-2011, 10:59 PM   #1
"Rigid" electrical conduit
Hi,
New guy to the board here. I am in a quandary.
Can G.I. pipe fittings be used in "rigid" conduit applications in Chicago? I am re-directing a service to a main box and I cannot find "rigid" style conduit nipples in the sizes I need but I can get them in galvanized iron.
I am speaking specifically about 1 1/4" nipples. I have access to a Rigid
pipe threading machine, but it doesn't have a nipple chuck. I suppose I could rig up one and make my own nipples but that means buying a 10' length of pipe for less than 2 ft combined total inches of nipples.
Can someone help me with this quandary?
TIA
Karl Andrews
Karl Andrews is offline   Reply With Quote
Old 08-21-2011, 09:31 AM   #2
Electrical Contractor
No, galvanixed pipe can not be used.
Most hardware store will cut and thread the nipples for you.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-21-2011, 09:36 AM   #3
Is the 'no' a Chicago rule or another rule?
jlmran is offline   Reply With Quote
Old 08-21-2011, 09:40 AM   #4
Super Moderator
There must be an electrical supply house around --
Where are you located?
Old 08-21-2011, 09:43 AM   #5
Code05's Avatar
Plumbing pipe is not the same as rigid conduit. The inside can have rough edges that will nick the wire. Go to a supply house, they will have what you need.
Code05 is offline   Reply With Quote
Old 08-21-2011, 09:45 AM   #6
It might not be best practice, but is it forbidden?
Old 08-21-2011, 09:51 AM   #7
Licensed electrician
The NEC requires things to be used for their purpose. Plumbing pipe is not listed for electrical usage.
Code05 (08-21-2011)
Old 08-21-2011, 09:52 AM   #8
Super Moderator
I believe the threads on rigid conduit are straight and plumbing pipe has tapered---so yes it is prohibited.
Old 08-21-2011, 10:02 AM   #9
Code05's Avatar
Rigid is tapered.
344.28 Reaming and Threading. All cut ends shall be
reamed or otherwise finished to remove rough edges. Where
conduit is threaded in the field, a standard cutting die with a
1 in 16 taper (3⁄4 in. taper per foot) shall be used.
The Following User Says Thank You to Code05 For This Useful Post:
oh'mike (08-21-2011)
Old 08-21-2011, 10:22 AM   #10
Super Moderator
Good to know----I'm not an electrician although I worked for one some years back-----
Old 08-21-2011, 11:07 AM   #11
The pipe fittings I have fit perfectly, so I'm not worried about the threads.
I'll check around, we don't have a lot of electical supply houses in my 'hood, and the "big box" stores dont carry a lot of larger size fittings although I know where a couple are.
Thanks for the help.
KA
Old 08-21-2011, 11:11 AM   #12
The hardware store I work p/t at doesn't carry 1 1/4 fittings, nor do we carry that size "rigid". Most hardware stores don't carry larger sizes. We dont even carry 1 1/4 in the catalog. I'll try to find the size nipples I need and if push comes to shove I can buy a piece of rigid , cut and thread it myself. I can jerry-rig a threading jig for the shorter pieces.
KA
Old 08-21-2011, 12:42 PM   #13
Just call me Andrew
One of these places should have it
http://maps.google.com/maps?q=electr...+chicago%2C+il
Andrew
secutanudu is offline   Reply With Quote
Old 08-21-2011, 02:19 PM   #14
What is plumbing pipe, by definition?
Old 08-21-2011, 03:31 PM   #15
Code05's Avatar
It ain't Rigid Metal Conduit and it ain't listed as such.
344.6 Listing Requirements. RMC, factory elbows and
couplings, and associated fittings shall be listed.
Humming / vibration in electrical conduit codybear Electrical 4 10-26-2010 07:21 PM
Underground Conduit donnyc Electrical 1 09-20-2010 02:29 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 09:48 AM
