Rigid Conduit Installation Help Needed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 07:38 AM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by Speedy Petey View Post
And why only 1-1/2"? Most places 2" is the minimum mast size. Is the service/feeder drop supported by the mast?
Must be a southern thing I because they don't get snow and ice.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-16-2012, 10:13 AM   #17
Rewards Points: 168
Hubs are not required inside unless you wasted money on an outdoor panel. Do you have a leak right over the service panel?
Old 03-16-2012, 02:50 PM   #18
Sparky
Rewards Points: 510
looks like the back side of a semi flush meter combo in the pictures, which would probably NEMA 3R
Techy is offline   Reply With Quote
Old 03-16-2012, 03:26 PM   #19
it's a 200a semi-flush panel/meter combo
socalsteve72 is offline   Reply With Quote
Old 03-16-2012, 03:29 PM   #20
Originally Posted by Julius793 View Post
We aren't understanding each other, take a 2 hole strap, drill out the stuco/concrete and use anchors. Why do you think you can only strap to wood?
Stucco is only an inch thick and i didn't think that it could support much of anything
Old 03-16-2012, 03:33 PM   #21
Originally Posted by brric View Post
No, it will NOT bottom out. Just to be nosy, where is your meter?
The hub connects the conduit to the meter/ panel see attached pic of outside garage wall
Old 03-16-2012, 03:46 PM   #22
Semi-Pro Electro-Geek
Rewards Points: 2,942
You've never worked on stucco, have you? You can't anchor anything substantial to it. It is entirely non-structural and fairly delicate. Trying to drill in an anchor from the back side will break out a chunk on the exterior.
mpoulton is offline   Reply With Quote
Old 03-16-2012, 03:50 PM   #23
My point exactly
Old 03-16-2012, 04:04 PM   #24
rrolleston's Avatar
2x4 or steel plate between the 2x4's in your garage could be used and you could bolt the straps to that to hold the pipe.
The Following User Says Thank You to rrolleston For This Useful Post:
socalsteve72 (03-16-2012)
Old 03-16-2012, 04:54 PM   #25
Licensed electrician
Rewards Points: 1,634
What does your power company say is acceptable support?
plummen (03-16-2012)
Old 03-16-2012, 10:47 PM   #26
SCE says 15" max distance between supports for 1 1/2 rigid conduit. I've got 7 feet inside exposed wall going through double header and rafter beams
Old 03-16-2012, 11:42 PM   #27
Ravenworks's Avatar
Not to sound like a dick,but why didn't you saw cut the stucco.
Ravenworks is offline   Reply With Quote
Old 03-17-2012, 06:33 AM   #28
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
You HAVE to be reading this wrong. 15 INCHES between supports on 1-1/2" rigid? That's absurd.
Old 03-17-2012, 06:34 AM   #29
IMO some people like the irregular patter on the edges when patched. It is less noticeable.
You can't saw cut perfectly for the box for obvious reasons.
Old 03-17-2012, 10:07 AM   #30
I did cut it nice and clean with a diamond blade, then chipped out with air hammer to expose chickenwire and tar paper to get my flasing in under the stucco and better finish like speedy petey said.
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
storm door - Installation help needed tooslo1 Remodeling 3 07-20-2010 05:34 AM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 08:31 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 11:42 AM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 05:15 PM
