Rigid Conduit Installation Help Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 10:27 PM   #1
Rigid conduit installation help needed
Q1-
isn't rigid conduit supposed to bottom out in hub on new service panel? I thought so, installed mine and the threads look fine but only threaded in about 8 turns then stopped. Same on the other end.
Q2-
i'm trying to figure out how to brace my service entrance rigid conduit in my garage wall to my service panel. the conduit is 1 1/2 inch and the studs are 3 1/2 (2x4) so there's no room for cross bracing behind the rmc.i was gonna brace then strap but no room(stucco exterior) any ideas??
Pics are attached any help is greatly appreciated-
Steve
Rigid conduit installation help needed-conduit.jpg   Rigid conduit installation help needed-conduit-2.jpg
socalsteve72 is offline   Reply With Quote
Old 03-15-2012, 10:39 PM   #2
Julius793's Avatar
Use straps
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 03-15-2012, 11:03 PM   #3
what should i strap to?....
i previously explained the problem, maybe i'm missing something
Old 03-15-2012, 11:05 PM   #4
Rewards Points: 3,256
A1....Tapered pipe thread. It only threads in so far and becomes tight when there is no more clearance between the threads.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
plummen (03-16-2012)
Old 03-15-2012, 11:14 PM   #5
Julius793's Avatar
Concrete or cinderblock what ever it is.
Old 03-15-2012, 11:15 PM   #6
I wasn't sure if it was tapered like std pipe thread, or supposed to be straight thread as i read about online.
Any ideas on strapping product(s)/ ideas on conduit supports ??
Old 03-15-2012, 11:18 PM   #7
It's stuuco on stud construction. no plywood, ony the framing to strap to.....see pics
Old 03-15-2012, 11:19 PM   #8
Is it a code requirement to support closer to the panel than your double plate? It looks pretty secure to me. How about wooden blocking, maybe a 2x and a 1x to the closest stud and a half clamp or that thin metal strapping with the holes in it?
Old 03-15-2012, 11:27 PM   #9
Code here requires bracing every 15 inches, i agree it's secure definitely no going anywhere but don't want to get called on it
Old 03-15-2012, 11:30 PM   #10
Julius793's Avatar
We aren't understanding each other, take a 2 hole strap, drill out the stuco/concrete and use anchors. Why do you think you can only strap to wood?
Old 03-16-2012, 12:01 AM   #11
Rewards Points: 324
more than likley gaulled threads.you should pre fit hub to conduit.don't know if it is wrong but when i pre fit hub to conduit put a little no-alox on threads.no more trbl.
oleguy74 is offline   Reply With Quote
Old 03-16-2012, 12:10 AM   #12
So you're saying it should bottom out in the hub?
Old 03-16-2012, 06:23 AM   #13
Master Electrician
Rewards Points: 3,768
No, it will NOT bottom out. Just to be nosy, where is your meter?
brric is online now   Reply With Quote
Old 03-16-2012, 07:10 AM   #14
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I highly doubt it. It looks fine.
This is NOT correct.
IMO it is FINE the way it is.
I also ask where the meter is?
And why only 1-1/2"? Most places 2" is the minimum mast size. Is the service/feeder drop supported by the mast?
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 03-16-2012, 08:25 AM   #15
Mast is for meter/service panel combo, min code here is 1 1/2' rigid for 200a panel i'm using 2/0 service wire
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 01:09 PM
storm door - Installation help needed tooslo1 Remodeling 3 07-20-2010 06:34 AM
Wire size and type in Rigid Metal Conduit Al the Diy guy Electrical 5 02-05-2008 09:31 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 12:42 PM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 06:15 PM
